C5 Corvette cooling fan adjustments?
I just installed my Intune and cannot find the adjustments for the fans. Are these preset?But advert says it will allow you to adjust these parameters along with some others that I do not see.
Y2K C5
Re: C5 Corvette cooling fan adjustments?
should be under the modify tune menu....
Went to stock tune and then adjustments,not there.Put in the Diablo tune went to adjustments not there either.Now what?
Y2K C5
what is there?
ok hers the files
- PCM_09357620_LastTuneWritten.grg
- (22.11 KiB) Downloaded 193 times
- PCM_09357620_Backup.grg
- (22.06 KiB) Downloaded 174 times
Y2K C5
after looking over this tune, the settings are lowered by 30* in the 93 tune, load it up and let me know what the temps look like...
I am having the same issue but I am hesitant about downloading the tunes that are posted earlier in the thread as they may contain other adjustments that I don't want or need.
"I just installed my Intune and cannot find the adjustments for the fans. Are these preset? But advert says it will allow you to adjust these parameters along with some others that I do not see."
I looked and looked but could not find the cooling fan parameters at all. I've installed a 180 degree thermostat and need to adjust the cooling fans.
Any help would be appreciated.
I would like to have this question answered as well but I am dealing with a 2002 Camaro.
RG
RG
you can't use someone elses tune files anyway, won't work for you.. tunes are tied/locked to specific vehicle by VIN number and engine calibration ID's..jonkeevy wrote:I am having the same issue but I am hesitant about downloading the tunes that are posted earlier in the thread as they may contain other adjustments that I don't want or need.
the preset tunes have the fans adjusted already as mentioned..
and the stock t-stat is already 187*... so won't really have any benefit/gain going to just a 180 anyway.. fans are already adjusted in the tune and are fine for that application...
