Problem Challenger 392 "No Bus"
IRONMAN77
Post by IRONMAN77 »
Good day. My English is not very good but I hope you understand me. I have a Dodge Chellenger SRT8 392 Inaugural Edition Model 2011, Trinity acquired a DS because I use a Neon SRT4 that also I have, now I get the update for 6.4 liters engines, try connecting with the Challenger, however I have problems, the first once you try it logged on and I thought the tune was installed, however when asked to return to the original configuration, told me that \"there was never saved\", then try and modify the original parameters of the car display I turn and sent me a message \"No Bus\" and it did not turn on the car, what I did was disconnect the battery for a overnight siguinete the plug and the car works well, I tried again this time I threw the message guarding the factory setting when suddenly trailed off the back of the car and daring display \"No Bus\", I returned to disconnect the battery and let it last night and this afternoon I hope to reconnect the battery to see if it lights. I can help. Obviously before attempting to connect the Trinity did the acutialización Challenger on page Diablo Sport.
IRONMAN77
Re: Problem Challenger 392 "No Bus"
Post by IRONMAN77 »
Any response???
is there still a problem, or it cleared up now?
IRONMAN77
Post by IRONMAN77 »
Unchanged yesterday reconnect the battery and the car lit and did not want to try again. The problem starts much the same setup and record it appears that the original configuration of the memory empty car and throws "Nobus", the attempt to connect with the button of ignition will try to do it with the key. Any recommendations?
RT23
Post by RT23 »
No expert here, but Never use button for tunes!!! Use key fob.
Your English is better than some that speak (or butcher rather) it as a first language, brother! :P
If you don't get it sorted out, DS will help you, they are top notch.
mikesrt8superbee
Post by mikesrt8superbee »
RT23 wrote:No expert here, but Never use button for tunes!!! Use key fob.
this is the case for some years. the button does not come out in my 2012 super bee.
