"Unable to find calibration update" error
Re: "Unable to find calibration update" error
Same problem. "Unable to find calibration update" error pops up. After that, it tells me to unplug the inTune and try again. I've unplugged it and tried a couple times and does the same thing.
- info.xml
- (532 Bytes) Downloaded 336 times
what vehicle is it?
I see an 09 chally and maybe an 05 car as well?
09 CHALLENGER. Was data logging on 05 Magnum (not supported and wasn't intended to tune it)
oK< its asking for an update for the 05 model, what happens if you try to tune the 09?
It works fine when I tune the 09, backs up stock tune and writes the new tune. I have returned to stock for now but still wouldn't update. Should I remove the 05 or both from memory and retry?
Tried to delete 05 but not all of the 30 code digits fit.
Tried calling Tech support but after on hold for 30 minutes the costs were piling on. Any help on this ????
so, you dont need a cal update at all?
the tool is up to date...you dont need anything....
So what do I do about the error message? How do I delete the 05? What happens when I need an update?
Shouldn't the Intune tell me that it's up to date instead of error unable to find calibration update?
it wont check for a cal update unless the tool itself is up to date, all good.
Is this something that happens every time. I just punches one and try to install today. 01/4/13. And my PCM shows error accrues in intunes. 2010 challenger Rt. cai with delta 40s
what is the error message?Mwtaylor wrote:Is this something that happens every time. I just punches one and try to install today. 01/4/13. And my PCM shows error accrues in intunes. 2010 challenger Rt. cai with delta 40s
While checking for updates error# 12029
thats usually a firewall error...is that a possibility?
can you try disabling the firewall?
Same error has occurred when firewall off. It always states that Intune update has stopped working. Not sure what is going on. Also I read in handbook something bout Belkin USB port or something. Well my wireless is Belkin. Do u think that is a problem
