2009 DURAMAX DPF QUESTION
Does the in Tune have a DPF delete file a 2009 Duramax.
Re: 2009 DURAMAX DPF QUESTION
We do not offer any DPF delete tunes.fridgeguy wrote:Does the in Tune have a DPF delete file a 2009 Duramax.
Legally you cannot remove any emissions equipment. DiabloSport will not help you break the law. They're looking for CARB certification.
Thanks for the response. What are the horsepower levels available for this truck and are the tunes the same as the Trinity?
40hp, 100ftlbs
60hp, 150ft/lbs
80hp, 195ft/lbs
100hp, 220ft/lbs
Plus you can stack it with the Extreme Power Puck for an additional 100hp and 250ftlbs.
Tunes for the inTune and Trinity are the same.
60hp, 150ft/lbs
80hp, 195ft/lbs
100hp, 220ft/lbs
Thanks Mike. I put the 100 hp tune in, all I can say is YIKES!
I can imagine. I want a diesel so bad. So easy to make tons of power. Did some research on swapping an LML Duramax into my Yukon Denali, and although it'll fit, I'll lose all wheel drive. With 1000ft/lbs, I need AWD.
fridgeguy wrote:Thanks Mike. I put the 100 hp tune in, all I can say is YIKES!
