2012 Ram 5.7 Hemi
dtru1222
Re: 2012 Ram 5.7 Hemi
Post by dtru1222 »
Well for us crew cab guys who dont have traction issues... I would like to play around with torque management.
Scotty85
Post by Scotty85 »
Ummm... I DO have a crew cab. And I DEFINITELY have traction issues.
dtru1222
Post by dtru1222 »
Well... thats good for you....
Again for us who DONT have traction issues. Is there any way to adjust torque management.
white_lightning
Post by white_lightning »
custom tune could help cause traction issues. :wink:
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
whitelightningtuning@yahoo.com
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
greychevy
Post by greychevy »
Have you guys started working on making the intune for Chrysler 2011+?
Ethan
First & only 4th gen 4x4 in the 12's NA 12.747 @ 104.07
2012 Black SC 4x4 1500 Hemi, Coated ARH longtubes, Vararam intake,
Circle-D, efan, 2010 frontend swap/4.56 gears, Trinity w Greene Racing tune,
Moe's 87mm throttle body, AEM Wideband
white_lightning
2011 & 2012 Ram tuning is available now with Trinity.
My Ride:
dtru1222
Post by dtru1222 »
white_lightning wrote:custom tune could help cause traction issues. :wink:
I have a custom hemifever tune. Its the crappy 3.55 gears and brand new tires that ensure that I dont have traction issues.
white_lightning
then you probably need a gear swap to have traction issues. your hemifever custom tune should make more power than a canned tune.
your hemifever tune + 4.10 or 4.56 gears should smoke your tires!
My Ride:
MeanSRT
Post by MeanSRT »
Cjm wrote:So far so good, any way to kill that dam eco icon?
You can turn off the ECO icon in the display settings menu of the truck, not with the Trinity.
stryker6040
Post by stryker6040 »
might be a stupid question but i just picked up a trinity for my 2012 the owners manual says 87 octane will work but 89 is recommended. since the trinity has an 87 octane option is this going to hurt anything in the long run
using 87 with the 87 tune is fine :)
tech@diablosport.com
brentwood
Post by brentwood »
i'm loving my ds trinity tune so far.... Everything is working well, but i'm unable to calibrate tire size.
is there an update that will allow us to callibrate tire size yet?
Scotty85
Post by Scotty85 »
I just don't get all these guys saying they see/feel no difference whatsoever after installing the tune, or even that their truck is worse than before flashing. They are either not flashing the tune properly, or they have a completely unrealistic expectation of what this tune is made for. I know I absolutely love how my truck drives now, in every aspect. I can blow the tires off if I want to, or I can drive like a little old blue-hair and baby it. And this is even after reverting back to the 87 canned tune. Sure, I made some modifications to shift points, WOT fuel, etc, but out of the box the Trinity has made a night-and-day difference in my truck overall. This is with 3.55 gears and an open diff. with 22s on it. (even though most of the time both tires spin) Kudos to DS for making it happen.
Tyrant
Post by Tyrant »
Scotty, different combos would explain it, different ratios, trim levels (weight) etc...
some expect to blow the tires off from the start but when they dont get that feel as is they have been screwed, as far as i'm concerned the diablo did exactly what it promised - turned of MDS, less TM, much better drivability. my 0-60 times are 7.8secs and unless the road is crap i cand even get the tires to squeal but that can be attributed to the 3.55 gears, added weight of crewcab spec and 4wd. but that doesnt bother me coz at passing speeds where i care about the truck is an animal.
i guess people also see times like member chaney for example and feel that something is wrong, but they also fail to see that he has got alot in mods on his truck + 4.10's.
eric448503
Post by eric448503 »
I have the same setup. 4x4, crew cab, 3.55's. I run consistent 6.4-6.5 0-60. Load the converter up to 1500 and let her rip.
