Cant Register inTune
drew300
Post by drew300 »
My wife bought me a brand new inTune from the dealership for xmas.
So I plugged it in and the application kept crashing; the registration as well poped up but only for a few seconds then crashed. After a few attempts at this the inTune.exe finally decided to stay open and not crash. It went through the updates but once complete the inTune said that I must register the product first before the updates would be applied.
I've read through these forums and the only way for me to register is throught that registration window that does not pop up anymore. There is no option anywhere in the inTune.exe to register.
Here is a copy of the info file; i've noticed there is already a VehVin already?? According to a quick google search of the VIN the vehicle is located in New York. I bought the inTune NEW from the dealer in Canada.
Please advise?
- Andrew
info.xml
(435 Bytes) Downloaded 258 times
drew300
Re: Cant Register inTune
Post by drew300 »
I decided to just hook it up to my 2007 Chrysler 300 V6 3.5 and I got the message: "PCM calibration for (VIN) currently not supported. Check for update". Which it tells me to hook up to a PC with internet and it will download the correct PCM.
Connect to PC and nothing happens. inTune.exe trys to download an update but will not work because I havent registered my inTune because I have no way to register.
Please advise?
-Andrew
EDIT: added new info file with my actual VIN
info.xml
(504 Bytes) Downloaded 289 times
drew300
Post by drew300 »
Tried calling tech support a few minutes ago and the automated service told me an operator was not available and that it was exiting the system. :(
drew300
Post by drew300 »
Thanks Mike for the help buddy!
Mike was able to send me the registration file plus the PCM calibration file. Took all of 10 minutes to fix.
What a difference in the car :) :drivingbad:
Thanks again Mike!
157dB
Post by 157dB »
How bout shooting me that registration file.
I have no eMail address to receive one
from the online registration...
Thanks Mike.
reg files are specific to each tool, post your info.xml file from the intune drive please.
157dB
Post by 157dB »
Sorry, double posted...
You took care of me over here...
http://www.diablosport.com/forum/viewto ... 82#p233482
shadow41
Post by shadow41 »
cant register mine either here is the info file MIKE please help... u seem to be the man..
[email protected] if u need it..
info.xml
help me mike I need help!!!
(444 Bytes) Downloaded 254 times
Vladimir5145409
Post by Vladimir5145409 »
mikel wrote:reg files are specific to each tool, post your info.xml file from the intune drive please.
Hello, Mike!
Please help! Same problem: Unable to determine VIN and Calibration ID.
I need to change Axle Ratio as soon as possible!
P.S.
Chrysler 300C 3.5 V6 2007
Engine EGG
Transmission NAG1
info.xml
(1.89 KiB) Downloaded 235 times
Last edited by Vladimir5145409 on Mon Mar 31, 2014 2:38 pm, edited 1 time in total.
try updating the tool on a PC...
Vladimir5145409
mikel wrote:try updating the tool on a PC...
Thanks.
New update is not working.
The same problem.
in Vehicle Info:
"Unable to determine VIN and Calibration ID"
in Tune Vehicle menu:
"The vehicle is not supported"
Help me please!
E-mail: [email protected]
EGG 3.5L High Output V6 24V MPI Engine
DGJ 5-Speed Auto W5A580 Transmission
New info file here:
info.xml
(1.8 KiB) Downloaded 283 times
Datdirtys
Post by Datdirtys »
need help with registration also. :punisher:
info.xml
(435 Bytes) Downloaded 213 times
CBenningfield
Post by CBenningfield »
<?xml version="1.0"?>
-<tool_info>
<main svn="8521" sw_rev="1r04i" full_version="InTune-1r04i 08/03/2015 01:32:36 PM"/>
<registration status="1" sn="J299W09-4"/>
<cal_id PCM="55351430BH, 010600"/>
<restore bc="0" vin="3D7MX39A07G848322" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="1r01e" mfr="DCX"/>
<db pid="1r01b" tune="1r02a" mfr="FORD"/>
<db pid="1r01a" tune="1r02o" mfr="GM"/>
<license tuned="0" avail="1"/>
<unsupported vin="1C4SDHDT5CC275706" oem="DCX" calid="68161722AB"/>
<unsupported vin="3D7MX39A07G848322" oem="DCX" calid="55351430BH, 010600"/>
<updates count="8"/>
<oem tool_oem="DIABLO"/>
<reg reg="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"/>
</tool_info>
donandyno
Post by donandyno »
Hallo Mike,
ihave the same problem an i hope that you can help me. I bought a used restored InTune.
My problem is that I could register it but the registrationfile was not saved.
My Vehicle is a Chrysler 300 C 5.7 HEMI with a 5-Speed automatic transmission.
Thank you very much.
info.xml
info.xml
(2.59 KiB) Downloaded 173 times
J.Kidd
Post by J.Kidd »
Mike (anyone else),
Can you please supply me with a registration file? (info file attached).
John
info.xml
(1.72 KiB) Downloaded 173 times
