2012 Ram, Knock on 91 Tune
popcenator
Post by popcenator »
I'm running the 91 tune with 93 octane 10% ethanol added (it's the only 93 we have). I attached a log, just wanted to see if this is normal. ST spiked up to 6.5 for a brief moment.
If I need another log or any more variables to include let me know.
Update: I added a couple more lengthier logs. I added 2.5% fuel to 1-3.8K and 3% to the midrange on both the home and work files. I may need to bump it up to 5% on both.
91HOME93.LOG
Added 2.5% fuel under 3.8K and 3% above.
(858.8 KiB) Downloaded 355 times
91WORK93.LOG
(1.09 MiB) Downloaded 273 times
91ON93.LOG
(136.35 KiB) Downloaded 308 times
dtru1222
Re: 2012 Ram, Knock on 91 Tune
Post by dtru1222 »
I got up to 6 on my 12 5.7 also. The Diablo tune actually increased the ST retard. I got a custom Hemifever tune and it never gets above 2.5 now.
popcenator
I'm just wondering if maybe the 91 without ethanol would make a difference over the 93 with ethanol
eric448503
Post by eric448503 »
After reading this I started watching my knock gauge. On the 93 tune, I have zero knock at any RPM. I don't know whats going on with you guys
white_lightning
Post by white_lightning »
eric448503 wrote:After reading this I started watching my knock gauge. On the 93 tune, I have zero knock at any RPM. I don't know whats going on with you guys
knock can vary some from truck to truck on the same tune.
are you looking at Short Term knock or Long Term knock? ST is the one you need to be watching most of the time.
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
white_lightning
popcenator,
looked at part of your "home" log, and most knock seems to be above 4000rpm. not bad, but I prefer to see no more than 1 to 1.5 degree of knock.
did you try pulling spark? my first try for reducing knock would be less spark, not add more fuel.
My Ride:
popcenator
I added about 5% fuel at all RPM ranges and reduced spark 1* at all ranges. It's much less now, peak is usually around 3.5 which I know is still too high, though normally not above 2-2.5. It occasionally spikes above that. It runs great, I just want to avoid doing any damage. I'll get another log today on the way to work. Should the 93 octane with 10% ethanol be more than enough for the 91 tune?
I'm going to reduce the fuel back to normal, and take a couple more degrees of timing at all ranges and see what that does for me.
eric448503
I was looking at both, neither budge from 0.0 ever
popcenator
I set the fuel back to normal and reduced spark 2* at all RPMs and still getting spikes of 4-5. Not often, but they're there. I'm planning on getting a custom tune in the next month but would like to figure this out in the meantime. I'll post log of my trip home from work tonight. Thanks for your help everyone.
I've read that ST knocks around the shifts are normalish or nothing to worry about but I just want to make sure that's what's happening.
white_lightning
yes, some ST knock at WOT shift points is common.
93 octane with 10% ethanol should still have 93 octane and perform similar to straight 93. it should be plenty octane for a 91 tune.
have you chosen a custom tuner?
My Ride:
popcenator
I was thinking hemifever because Sean was the only one I knew of, I haven't shopped around much though to see what options there are.
white_lightning
Sean is a good tuner. there are a lot of other Dodge CMR tuners, though: https://www.diablosport.com/dealer-locator.html
My Ride:
popcenator
Are a lot of them similar, as in, send a log and the tune gets refined, or are they more of an in person dyno tune?
white_lightning
some are e-mail tuners, e-mail log and get tune refinement, or log and tune in person.
I am an e-mail/log in person tuner.
another option is to do logs on a dyno and e-mail to a tuner.
some tuners have a shop and own their own dyno.
the dealer locator should show you which tuners have an in-house dyno.
My Ride:
popcenator
yeah unfortunately there are no tuners even close to me, at least not within 400 miles. You've been very helpful so I I'm interested to know more about your tuning.
