Dodge charger LT and ST Knock 93 & 91 OCT at Cruising Speeds
mraisi
Post by mraisi »
Dear Mikel,
Im really pleased with the DS T1000 Ive got better performance.
I have a dodge charger R/T 2011 with Volant CAI + Magnaflow cat back and i use 93 OCT fuel and 0-60 timing before tune = 5.7 sec after = 5.2 with 93 OCT. :lol:
but the only problem is that im getting ST & LT knk at the speed of 50 miles between 1000 RPM to 2200 ST= up to 6.5 LT = 3.5 :drivingbad:
with the 91 OCT ST= 6 LT=1 at same speed RPM .
my friend has a charger stock with DS 93 OCT and he doesn't get any LT knock and we use same fuel.
please help me eliminate this problem tell me what i need to modify or change. i tryed adding 5% fuel to 91 OCT and it got worse. I added the same to 93 OCT and it reduced the LT to 1.5 but the car response performance was worse.
Charger 2011 RT with Volant CAI , BBK TB 85 , BBK Long Headers , BBK mid pipe with HF cats , MaganaF Catback, SLP 25% underdrive pully ,180 JET TSTAT, NGK Iridium XI , Diablo sport Trinity tuned by Johan. CAM coming soon
Re: Dodge charger LT and ST Knock 93 & 91 OCT at Cruising Sp
can you post a log please?
mraisi
Post by mraisi »
OCT93.LOG
(872.13 KiB) Downloaded 315 times
mraisi
Post by mraisi »
here is the 91 OCT LOG that shows both ST and the LT knock. :(
OCT91.LOG
(87.36 KiB) Downloaded 267 times
mraisi
Post by mraisi »
Any update?
white_lightning
Post by white_lightning »
did you try pulling some spark from where it is knocking?
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
mraisi
Post by mraisi »
no I didn't ..
I'm not too pro could you help?
does it decrease the performance ?
last update ST = up to 6
LT = up to 1.5
x4x
Post by x4x »
Hi
last time I monitoring Knock I found strange numbers
ST = 6 and LT = 2 some times more
I switch to 91 tune, but I got the same result
I did not find such these numbers before .
I wish to know the reason of the issue and find a solution.
I wonder, Where is the support from DS .
Dguth
Post by Dguth »
I'm having the same problem with my Jeep SRT8. Pulling st knock up to 9 and LT knock between 1 and 2. I've been trying to datalog it to understand what's happening. It seems interesting so many people seem to be having this problem. Wonder if the knock sensors are just too sensitive or something else. The knock on my Jeep occurs in both the 93, 91, and stock tune. I thought it might be bad gas or oil in my manifold; I just finally got my catch can installed.
Would like to hear feedback from others on how they have resolved this problem or what might be other causes?
mraisi
Post by mraisi »
any updates ?
white_lightning
when you load a tune, you should be able to go to "Modify Tune" and modify WOT spark. look at your log, and pull the amount of ST knock you have vs rpm from WOT spark and see if it helps reduce knock.
when you have knock, less spark will usually help performance.
My Ride:
mraisi
Post by mraisi »
Its really sad not to get any reply for almost one month.
ive posted the log as asked but never got any support.
thanks white lighting for trying to help.
white_lightning
you're welcome, mraisi.
My Ride:
