Hi,
I have 12 Charger RT with Mopar CAI and Borla Cat-Back exhaust. Am running 91 tune but I could not see any improvement in the car except a better response after increasing the throttle parameter to 20% .
my friend suggest to me to add 5 % fuel WOT as well but I am no expert in this field. is that OK to add 5% more ??
Tuning Question - CAI and WOT
12ChargerRT
Re: Tuning Question - CAI and WOT
64 Views ,, 0 Reply !!
It's fine to add fuel. Diablo adds 5% to their CAI tunes off the bat. DOn't add fuel just to add fuel though. Do some logs and see if it's warranted. If you see ST or LT knock, add fuel in increments of 5% (up to 15% or so max) and see if it goes away. Adding 5% won't hurt anything if you don't want to log first and just want to see if it feels different, but I would still do some logs, especially if you add more than 5%. No need to add fuel if it's not needed.
Anybody know if a CAI tune adds fuel in all ranges or just the upper rpms?
2009 Challenger RT Auto
AFE STAGE II CAI
U7135 V. 9r29
Catch can
AFE STAGE II CAI
U7135 V. 9r29
Catch can
12ChargerRT
SRT8York wrote:It's fine to add fuel. Diablo adds 5% to their CAI tunes off the bat. DOn't add fuel just to add fuel though. Do some logs and see if it's warranted. If you see ST or LT knock, add fuel in increments of 5% (up to 15% or so max) and see if it goes away. Adding 5% won't hurt anything if you don't want to log first and just want to see if it feels different, but I would still do some logs, especially if you add more than 5%. No need to add fuel if it's not needed.
Shall I add on all RPM ranges ? Thanks,
12ChargerRT
+1Hemi1014 wrote:Anybody know if a CAI tune adds fuel in all ranges or just the upper rpms?
popcenator
Like mentioned above, do a log of the tune and pay attention to ST and LT knock, if you see it, add the fuel in whatever RPM range it's knocking, if you don't then don't bother. Just don't go blindly adding fuel if it's not warranted.
12ChargerRT wrote:SRT8York wrote:It's fine to add fuel. Diablo adds 5% to their CAI tunes off the bat. DOn't add fuel just to add fuel though. Do some logs and see if it's warranted. If you see ST or LT knock, add fuel in increments of 5% (up to 15% or so max) and see if it goes away. Adding 5% won't hurt anything if you don't want to log first and just want to see if it feels different, but I would still do some logs, especially if you add more than 5%. No need to add fuel if it's not needed.
Yes, you can add 5% in all 3 ranges and be fine. I'm pretty sure that DS does it at all ranges in their CAI tunes, but I'm not 100% positive. 5% won't hurt as it's only at WOT anyway and not just regular cruising speed. You would need a CMR tune for that. I would still recomend logging though to see if you're getting any knock.
12ChargerRT
if there is no LT & ST, in this case I understand that there is no need to add Fuel !! is that right ???
popcenator
Correct.
