ABS Issue, can't update tire size on 2005 Durango
Re: ABS Issue, can't update tire size on 2005 Durango
options/troubleshooting/show calid?
jackedmech
Sorry for the delay, I just got back from the USS BUSH. I am not sure what your response is. I still have the issue. ABS flashing, will not set cruise control, and when it is run through a brake analysis machine, it says tire size is causing this. Any updates I can add to my tuner to fix this?
if you restore tire size, does it go away?jackedmech wrote:Sorry for the delay, I just got back from the USS BUSH. I am not sure what your response is. I still have the issue. ABS flashing, will not set cruise control, and when it is run through a brake analysis machine, it says tire size is causing this. Any updates I can add to my tuner to fix this?
