CMR Download on site
I cant find where the downloads are on the website to update my CMR so I can tune newer vehicles. Any help would be great, thanks. Current version 4,7,0,92
Re: CMR Download on site
log out, log back in, you should see cmr dealer button now
Got it!!! Thanks!!!
Was also wondering. This is my first 06 tune and first intune as well. The car has a sct tune in it now. When I get the base file tune from the intune and open in CMR the data is all junk. Am I doing something wrong or is it because of the sct tune?
How can I find a stock FBLF152 file?
Thanks, Chad
Thanks, Chad
can you post the file?
Ok. Forgive me. Im still figuring out this all out.
Once I updated my CMR I was able to read tune from the car. I opened CMR and selected the tune from the intune as the tuning fille, Did not select a fixed file. I pressed ok and it checked the website and got a template.
I open the software and compair and there are no differences, so I assume I am starting from a good template.
I mess around with start up and idle as this is my first ETC controlled Ford.
Decide to do a base line pull to see how close fueling is.... It pulls to 3500 and noses over. Fueling is all over the board.
After some messing around. I opened the stock file, Checked it, Restored it backinto the car and did a pull. It pulled to 5500 no probelm. So I decided to take the tuning file and make everything in it to match the base file. Flashed it to the car and it pulls to 3500 and noses over. Do I have an issue with the wrong template????
what did you change?
post the file....
post the file....
This is the factory backup that came from the car that works great when I flash it "back to stock" If I open it and say save as a different name and flash it to the car it wont rev past 4000.
Thank you in advance for any help.
- PCM_FBLF152_Backup.frg
- (483.82 KiB) Downloaded 550 times
what Id like to see is the file you changed that causes the issue...
This is one of the files I was trying.
Following is the process I used.
I updated the intune. Then installed one of the can tunes from the intune into the car so it would save the original. Then I hooked up the intune to my laptop and transferred that file to the customer file in CMR. Then opened cmr and chose that "backup"file as the tune file. I pressed ok with no template or fixed file selected. It said checking diablo site> template downloaded, etc. Then from there I proceed to tune. Changed some stuff for idle, etc and it worked great. Went to get a baseline and it noses over. I thought it was something I changed so I messed with some stuff and it still did it. So then I restored the original backup that was in the intune and it pulled fine. So I opened the same original backup tune that I had saved into the CMR. I then changed the cooling fan on temp and loaded it into the intune and then flashed to the car. It nosed over with this "original backup" tune with only the cooling fan changed. So I figured I messed something up.
The car will fine if I install original backup from intune only. Any tune file that was in cmr will nose over. Thanks Again!!!!!
- pcm_fblf152_cams_g.frg
- (444.44 KiB) Downloaded 525 times
I dont see anything obvious, lets see what the tuner thinks...theshop wrote:This is one of the files I was trying.
I messed around with it last night and instead of using the original backup file I loaded the diablo 91 octane tune then opened "last tune written" (91oct) and it seemed to work ok. It got late so I will know for sure this morning when I get it back on the dyno and make some changes.
