Trinity Chrysler 300 3.5 Tire Size won't change
darkstarsinner
Post by darkstarsinner »
So I hooked up my Trinity to my 08 Chrysler 300 3.5L Limited. Everything seems to work okay. However when I go to change my tire size (Trinity automatically shows it as being on 20" wheels) it will fail to flash every time. I am currently running the 89 tune flash file= dcx_gas v.1r09e Bus: CAN SCIA SCIB VPW and my saved calid: 05187030AH. Any help would be greatly appreciated.
darkstarsinner
Re: Trinity Chrysler 300 3.5 Tire Size won't change
Anybody?
we'll have to look into this...
darkstarsinner
Thank you. Is there any update as of yet? In the process of purchasing much larger wheels and would like to be able to calibrate the speedo.
does it let you enter the tire size, and ask you to cycle the key?
darkstarsinner
It does. But after I cycle the key it says the change failed.
it should be working then, despite the error, confirm with a GPS ;)
darkstarsinner
mikel wrote:it should be working then, despite the error, confirm with a GPS ;)
I don't have a GPS. Is there anyway updates will fix this?
change it to a small value and see if the speedo goes out of whack, if so, its working :)
darkstarsinner
I figured it out. I had to change the tire size BEFORE I flashed the tune. Then it stayed. Anything after would fail.
typan
Post by typan »
Mikel, would it make any sense to do a wheel size change if the new wheel size is only 1.4% difference over the original size?
1.4%?
No....
