2012 dodge durango rt intune dcx
The new update that was done to the intune dcx does not work like it used to with 1r03b. The 1r03c does not led me mod the shift point or Max MPH. And I have the ABS light on even after restoring original tune
Re: 2012 dodge durango rt intune dcx
After the update I tuned my 2012 Dodge Durango rt with the Diablo tune and my car started chocking and smelled like pure gas and then my car turned off
That suck hope u got it fixed Iam thinking of getting a In tune Wondering if I should get one
2012 Dodge Durango R/T
The newest update should fix all of that except the ABS light. They're working on the ABS fix and should be in later this week. The ABS light is tied to changing the tire size. If you leave that setting alone, you will not have the ABS light issue.
Now, since you did change tire size, no matter what you do you're going to have the light on until diablo comes out with the fix.
I have the Intune DCX and have no issues right now. I've loaded the 91 tune, adjusted parameters, restored stock, loaded the Diablo Tune(93 octane) and adjusted parameters on the Diablo tune after install.
