2005 Ram trans tuning
kredrocket
Hi i have a 2005 dodge Ram 1500, im tuning with the Intune and ive been having this problem since i got it several months ago. The intune doesnt read mi TCM so their is no trans tunnig. ive contacted youre Tech support several times,their is another thread i opened about the issue but i couldnt find it. you guys try to help me out but nothing you do works on this tool. i have custom PCM tunes for a bigger cam and that works good but it doesnt give me TCM tuning options. I get no CAL ID for TCM. I dont know what to do, I need to get TCM tunning. ive thought about getting a Trinity but i dont know that that will fix the problem. Is it my truck or the intune? is there any other way you guys can help me out?
Re: 2005 Ram trans tuning
post the info.xml file please.
kredrocket
you're on an older test version, please let the updater run then click update/check now and let it update.kredrocket wrote:here it is...
kredrocket
ok i updated it and there is no change, i still cant do TCM tunnig. ive tryed every update and a couple monthe ago a tech guy had me load some file to fix the problem but didnt fix the problem. ill post it...
- info.xml
- (485 Bytes) Downloaded 108 times
- cdrom-1t01ja.itf
- (2.58 MiB) Downloaded 126 times
drag/drop this to the intune drive and let it reboot pleasekredrocket wrote:ok i updated it and there is no change, i still cant do TCM tunnig. ive tryed every update and a couple monthe ago a tech guy had me load some file to fix the problem but didnt fix the problem. ill post it...
- InTune-1r03f.itf
- (1.56 MiB) Downloaded 140 times
kredrocket
ok its rebooting now
kredrocket
I tryed it on my truck and its still the same problem, trans tuning doesnt appear anywhere. ive been thinking of trying out a Trinity but i realy dont want to fork out $600 and have the same problem. but i dont know if its the intune or the truck
have we tried forcing a cal update to the vehicle?
kredrocket
No it hast had a force cal update
thats the next step, give us a call when you get a chance with the tool powered up in the truck and request that we force a cal update to see if TCM support will show up.
kredrocket
Ok.. so i called tech support and had them do a force CAL update, went though the whole thing loaded it to the vehicle and there was no change, is this all i can do? Whats are my options?
turns out there is an issue with the way intune sees the TCM calid vs Pred/Trinity, we're looking into it.
kredrocket
Ok, well hope you get it figured out soon, ill be watchimg for an update.
