Available Adjustable Parameters For DCX?
richmace
Post by richmace »
What are the adjustable parameters for the intune i1000DCX? All I can find on mine are the following:
Adjustable parameters for 91 Octane and Diablo Tune on my Intune
Cooling fans AC Off
Cooling fans AC On
Idle
MDS
Rev and speed limits
Throttle
Tire size
Traction control
WOT Fuel
WOT Spark
I thought we would be able to adjust cooling fan temp, cats, ext.
2011 Dodge Challenger 392 SRT8 Inaugural Edition #159 of 392 Built. Deep Water Blue with White Stripes, Tremec TR6060 Six Speed Manual, Options Group 2, Mopar Appearance Package, Arrington Performance Carbon Fiber CAI. Diablosport Intune, SLP Cat Back with Loud Mouth Mufflers, 180 Degree Thermostat.
Re: Available Adjustable Parameters For DCX?
Im confused, you list cooling fan adjustments, then say you thought you could adjust them?
They are there :)
Disabling rear o2 sensors is something that requires a custom tune from a CMR tuner.
richmace
Post by richmace »
Maybe I'm confused lol, so how would I go about adjusting the fan to come on at a lower temp once I install my 180 degree thermostat? There are no temperature settings listed on the menu.
Also is skip shift delete supposed to be on the intune parameters cause I don't have that option either.
skip shift is generally disabled in the tunes, if not, post the last tune written and I'll disable it for you.
The fan settings are in the menu you listed:
Cooling fans AC Off
Cooling fans AC On
You in there and set the on/off temps of the fans when the A/C is on and when the A/C is off.
generally lower them all by 20* for a 180* tstat.
richmace
Post by richmace »
Great. I'll give it a try.
I seem to have all the issues worked out with my intune, the only other issue I am having is when I go into modify the 91 tune or the diablo tune and disable traction control it starts to load the tune, goes to 100% and when I get to the key cycle step it says error loading tune and has to revert to the backup tune. Any thoughts on this problem?
try just disabling the tc from the quick adjust menu, instead of doing it with the tune install.
richmace
Post by richmace »
Disabled Traction control from the quick adjust menu and it worked fine. Also figured out the fan control settings. :)
This has been my first Diablosport product, we got off to a rocky start but I am extremely happy with the support that you gave me to get me up and running!!! Now if this damn snow would melt I could test it out, the Challenger is still trapped in my Garage for another two and a half months :?
Thanks for all your help
enjoy :)
