help with misfire
gsvar2004
help with misfire
Post by gsvar2004 »
i seem to be getting some random misfires on my data logging it kinda jumps around from cylinder to cylinder. two nights ago it was worse at idle then with throttle went away. today it was worse around 1500-2000 rpms.
i am getting counts anywhere from 2-10 each on the different cylinders each time i get a misfire is this bad or "acceptable"?
Re: help with misfire
what vehicle?
have you logged it stock?
gsvar2004
Post by gsvar2004 »
sorry its a 2010 silverado 5.3l 6speed
yeah all my logs are with stock tune. its very erratic tho its not a constant thing. two nights ago it was only at idle now its mainly with deceleration.
honestly i feel like its playing with me. i can tell you this tho every single time i decelerate like from highway speeds getting off an off ramp 2,4,8 cylinders misfire with 2-4 counts each.
im still under warranty just trying to figure out if this is significant. the only reason i started logging misfires was this damn thing idles so rough i knew somthing had to be going on and the dealer basically told me "well if you dont have a CEL there shouldnt be a problem"
sounds like its DOD related....try turning off DOD in the modify stock tune and log it again :)
gsvar2004
Post by gsvar2004 »
mike i guess my biggest question was is there ever a time when the numbers on the misfire counts are insignifcant. or should they always be 0 no matter what situation?
gsvar2004
Post by gsvar2004 »
ive ran logs at with both stock and 87 octane tunes, with DoD both on and off and i am still getting these low count misfires. mostly at idle and with deceleration. i get 2-4 counts of misfire on cylinders 2/4/8 every time my motor decelerates.
is this normal/common?
WTO
Post by WTO »
I'm watching this as I just got my intune out that I used to tune my Charger to try & diagnose the rough idle on my 2008 K1500. It will idle smooth then the tach will drop & it will get rough then it clears back up (all @ idle). Please post up anything you find or any suggestions. The truck has less than 30,000 miles and just went out of warranty. I did take it to the dealer and complain about the rough idle right before the warranty expired. I got the same reply "no CEL or misfires" so it's OK. I want to check on the misfires myself. My intune was way out of date because when I tried to use it the OBD functions were not supported. It's taking for ever to update....
Predator model U7191 (06 GTO)
iNTune i1000 (08 Z-71 LTZ)
2008 Z-71
03 Polaris SP 600
gsvar2004
Post by gsvar2004 »
im trying my damnedest to find all info i can. post up you misfire counts when you get it logged please
gsvar2004
Post by gsvar2004 »
it seems like the last few days i get a few misfires while driving but alot more misfires in park at idle and if i raise the rpms the misfires get much more prevalent. would this be "normal"?
WTO
Post by WTO »
gsvar2004 wrote:im trying my damnedest to find all info i can. post up you misfire counts when you get it logged please
I only got 2 on cylinder 6 from the 15 minute log I ran yesterday. I will run a few more when time permits to see if it is consistently that cylinder.
2008 Z-71
03 Polaris SP 600
gsvar2004
Post by gsvar2004 »
i ran a 10 minute log yesterday and had 2-4 counts on every cylinder. i know this is not "that bad" but i also know that months of 2-4 count misfires could end up being bad.
