Mike or Monte,
I am a noob at the Intune, but when I tried to install the 87 tune to my 13 Silverado 5.3 I haven't been able to get the AFM to go off. I know how to turn it off on the tuner but it isn't happening with the truck. I know from silveradosierra.com that there was a problem with the latest update and that a fix is on the way. Could either of you take a look at my file and help me get the AFM off? I am sending the ECM backup and LTW files.
I'll probably need help with specific directions of exactly what to do with the files you send me. Thanks in advance for the help.
Greywolf11
DOD can't turn off. Help Mike or MonteSS
greywolf11
- ECM_12649506_Backup.grg
- (65.52 KiB) Downloaded 97 times
- ECM_12649506_LastTuneWritten.grg
- (65.17 KiB) Downloaded 104 times
Re: DOD can't turn off. Help Mike or MonteSS
known issue with the last/latest intune update... there is a fix in the works...
here ya go man...
copy it into the TUNES folder in the intune usb drive to let it import...
then connect to your truck and select the custom tune, then install the tune...
- GreyWolf_NoDOD.grg
- (61 KiB) Downloaded 118 times
I have the sane problem with my turner I just got it and updated it and dod said it was off but was still working when I drove the truck?
drag/drop this to the intune drive, let it reboot, then retunenhemi42 wrote:I have the sane problem with my turner I just got it and updated it and dod said it was off but was still working when I drove the truck?
- InTune-1t03gc.itf
- (1.58 MiB) Downloaded 127 times
Thanks mike I will try it when I get to my truck!
Mike I tried to drag/deep the file and it said I didn't have enough memory? What do I do?
greywolf11
06MonteSS wrote:here ya go man...
Thank 06MonteSS! Worked and all is well. Top notch customer service. Can't go wrong with you guys!
Thanks again.
