that should be out today or monday.Emirates81 wrote:i got the custom tune maybe it has some issue then.
am asking about an update wich includes manual trans also
Thaks for your quick replies.
2012 wrangler update ?
Re: 2012 wrangler update ?
Still looking for a fix to NO Throttle response on 2012 JK manual trans. Help
I will gladly make you a custom tune, simply post up the backup or last tune written file please.noise.boy wrote:Still looking for a fix to NO Throttle response on 2012 JK manual trans. Help
Ok, so I tried writing the 91 with no throttle response on a manual transmission. I then restored and no problem. Then tried 87 tune and no throttle response then restored original. When i try to get tune from tool it says it doesn't have original back up or last tune. A custom tune will be fine if that fixes the problen of no throttle response. However is that good for just the single tune? I can see several situations where changing tunes will be advantageous.
At the risk of sounding ignorant, how do I "post up" the last tune? Help
let the tool read a copy of the backup, then connect it to a PC and export the backup file, then attach it here please.noise.boy wrote:Ok, so I tried writing the 91 with no throttle response on a manual transmission. I then restored and no problem. Then tried 87 tune and no throttle response then restored original. When i try to get tune from tool it says it doesn't have original back up or last tune. A custom tune will be fine if that fixes the problen of no throttle response. However is that good for just the single tune? I can see several situations where changing tunes will be advantageous.
Here is the original back-up:
- PCM_68090873AG.drg
- (91.11 KiB) Downloaded 222 times
here you go.noise.boy wrote:Here is the original back-up:
- pcm_68090873ag_perf.drg
- (72.72 KiB) Downloaded 257 times
Thanks Mike. Will load it shortly.
fyi. Just a test run. Big performance difference! So far so good! Thanks
Mikel, any update for 3.6 auto trans? I need some more performance. I didn't feel that power after using performance tune (test 91 & 93 oct)
Emirates81
noise.boy wrote:fyi. Just a test run. Big performance difference! So far so good! Thanks
Can u tell me how did you know that you got a big performance Plz ?
Where do you stay ?
Emirates81, I didn't use a dyno. Just took it out on the freeway here in TX. Local stretch has 75 & 80 mph speed limits. The big improvements are acceleration and torque with all my add ons. Bigger tires, bumpers etc.... Feels better than stock.Emirates81 wrote:noise.boy wrote:fyi. Just a test run. Big performance difference! So far so good! Thanks
Where do you stay ?
Emirates81
mikel wrote:that should be out today or monday.Emirates81 wrote:i got the custom tune maybe it has some issue then.
Any updates? It's Friday
update to fix the manual cals is here:
- trinity_dcx_gas-1t09ha_update.crom
- (2.89 MiB) Downloaded 269 times
