2012 ram with efan temp settings
Anyone know what to set the 3 fan settings for a 180 degree thermostat and efan with the dcx? I have the high mph fan set to 202 the low mph set to 194 and the fan on setting to 202. Once the truck gets warm the fan never shuts off. Thanks
Re: 2012 ram with efan temp settings
Bump for a educated guess....
generally lower all settings by 20* fromstock for a 180 stat.
Thanks... I set all settings to 202. It worked fine. I might lower it to 198 tho. The dcx is a little miss leading. Under the fan off section it has high mph ac fan on and low mph ac fan on.to me that is very contradictory. Thanks again.
they should not all be the same.
They are not all the same stock, so if you change them all by the same amount, they should still all be different values.
Well I changed it back to factory and all 3 settings where on 222*. So what do I do?
