3.5 long term and 6.0 short term knock
Re: 3.5 long term and 6.0 short term knock
here is the xml file.
- info.xml
- (466 Bytes) Downloaded 173 times
all up to date...
thanks. did you look at my stock log by any chance. i compared them both and still not sure what is causing all the long term knock,. can you tell from the log of the tune?
needs some fuel added...
wish i could, every time i change something in the tune whether it be the throttle or fuel, or both, it fails to right!
post the last tune written and I'll make you a tune for now...
Thanks.
- PCM_68139871AD_LastTuneWritten.drg
- (73.03 KiB) Downloaded 156 times
also here is the log that i did with this tune. the Long term knock is not as bad. but still there. i pulled fuse 2 thinking that resetting the addaptives would help. who knos
- 54968_00diablo93.log
- (523.99 KiB) Downloaded 166 times
heres 2 new files, one with 5 percent added, one with 10% added:
- pcm_68139871ad_10percent.drg
- (67.77 KiB) Downloaded 162 times
- pcm_68139871ad_5percent.drg
- (67.77 KiB) Downloaded 171 times
Added fuel or Throttle? i know we mentioned both in the above post somewhere. ill try them out and log. Thanksmikel wrote:heres 2 new files, one with 5 percent added, one with 10% added:
just fuel for now, lets sort out the KR first
i agree, just checkingmikel wrote:just fuel for now, lets sort out the KR first
so i installed the 10 percent one last night, everything went smooth. i logged it on the way to work today, it was raining its ass off so not able to really drive her hard. Also the first time driving her in the rain since the tune and removal of most of the TM.
puckered up a few times. lol will post logs when i get home!
puckered up a few times. lol will post logs when i get home!Re: 3.5 long term and 6.0 short term knock
Here are the 2 logs. both show some short term knk, and zero Long term. the towork file is first then the to home i was able to go WOT a few times.
Also i saw my intune updated today. do i need to reload the tune you sent me? id rather not unless it will make a difference!
- 54968_10%tohome.log
- (510.77 KiB) Downloaded 167 times
- 54968_10%towork.log
- (357.81 KiB) Downloaded 164 times
no need to reload it.
logs are much better....0 LT is a good sign, I think you are in good shape
