80% ish Throttle Position 2010 Camaro SS
edog
Post by edog »
Similar question as below about the Mustang at 75%. I have logged several passes and my Absolute Throttle never goes up past 80 something percent. Does this mean I am losing out on 20% power? Or is it just a glitch or something? I actually just showed my dealer today (they are cool like that) and he said I should ask. Thanks.
edog
Re: 80% ish Throttle Position 2010 Camaro SS
Post by edog »
BTW, I just got the "o" update and havent made a pass with it yet. I cant find any info on what the update did, but just in case I ask anyway.
edog
Post by edog »
Also just noticed the Launch control doesnt work correctly with the 91 tune loaded. The RPMs dont hold steady, it just goes slowly to redline. This is with the latest update.
80% is WOT on the GMs as I recall.
wow...ninja edit ;)
edog
Post by edog »
Cool, for the record it was 84%, I ran a log today.
Any idea on the launch control issue with the 91oct tune?
edog wrote:Cool, for the record it was 84%, I ran a log today.
post your backup and last tune written please....
Satch606
Post by Satch606 »
80% actual throttle position is 80% actual throttle position even though 100% is commanded. With GM, unless you tune all the torque management out of the motor, the PCM will always limit. The intune software does not have an available modification parameter for PCM side torque management. Only on the TCM side.
This has been an issue for a long time.
edog
Post by edog »
Backup
ECM_12635293_Backup.grg
Backup
(58.94 KiB) Downloaded 168 times
edog
Post by edog »
Last Written
ECM_12635293_LastTuneWritten.grg
Last Written
(58.75 KiB) Downloaded 168 times
edog
Post by edog »
The only mods to the 91 tune that I made (or intended to make) was the axle ratio bumped to 3.91.
Appreciate your time.
edog wrote:The only mods to the 91 tune that I made (or intended to make) was the axle ratio bumped to 3.91.
here are 2 files to try, let me know if either resolve the launch control issue.
ecm_12635293_launchcontrol2.grg
(55.21 KiB) Downloaded 172 times
ecm_12635293_launchcontrol1.grg
(55.21 KiB) Downloaded 157 times
edog
Post by edog »
Both worked, I selected reset parameters when it came up. I appreciate it.
Hopefully I will be back to 93 oct next time I go to the track, but it is great to have the options open if I need it. I go back and forth testing with/without the launch control so this really helps. Let me know if you ever want me to test anything out. Thanks again.
edog wrote:Both worked, I selected reset parameters when it came up. I appreciate it.
thanks for the quick feedback :)
yeah, for absolute throttle position parameter, that's normal...
if you log the commanded throttle position, it will be 100% when you're WOT to the floor...
