Monitoring Does Not Work
Post questions/comments about your Trinity for your Ford diesel truck.
Shaun93955
Post by Shaun93955 »
I have a 2009 F-250 with a 6.4L Diesel. I installed the economy tune from my Trinity T1000, version v.1r09b, but monitoring does not work. When I go to monitoring the guages come up, but there are no readings on them. It just shows the max and min limits. When I try to transfer data to my computer using dataviewer it says that no data was logged. Am I doing something wrong?
Re: Monitoring Does Not Work
should have a fix for you this week :)
Shaun93955 wrote:I have a 2009 F-250 with a 6.4L Diesel. I installed the economy tune from my Trinity T1000, version v.1r09b, but monitoring does not work. When I go to monitoring the guages come up, but there are no readings on them. It just shows the max and min limits. When I try to transfer data to my computer using dataviewer it says that no data was logged. Am I doing something wrong?
restore the stock tune, load this update, reselect the vehicle, and this should fix it :)
trinity_ford_can_diesel-1t09cb_update.crom
(4.14 MiB) Downloaded 1043 times
sohfast94
Post by sohfast94 »
What dash did you select?
Insert Clever comment here...
JROD22399
Post by JROD22399 »
I am having the same problem with my 09 F250. I tried the update in the link above and now the monitoring system freezes altogether! Before it was just all zeros on the gauges, but now wont even enter the program. Any thoughts?
options/show information, what is the version there?
JROD22399
Post by JROD22399 »
Trinity:
version: 1t09cb
Thank you in advance
try going to the loggingmenu and delete the default layouts, then restore the default layouts and try again :)
JROD22399
Post by JROD22399 »
Thank you for yet another speedy suggestion. Yet to no avail everytime I get to choose the function it freezes on that screen and it basically bricks up the devise.
can you tell me exactly what you are doing?
I have never had that reported before...
JROD22399
Post by JROD22399 »
Monitoring / Proceed / Ford_64_Diesel / Bricks up
When I was in 1r09b the gauges came up but had no function at all. I read the above and followed the directions. The tune took but the gauges just brick the device. Not sure if I did something wrong or what
sohfast94
Post by sohfast94 »
Go to options -> show information and post what it says for version.
JROD22399
Post by JROD22399 »
Trinity:
version: 1t09cb
go to logging and delete the existing layouts, then choose the option to restore default layouts.
JROD22399
Post by JROD22399 »
you suggested that yesterday and I just repeated the steps. Still have the same problem. :crashing: :blowup:
Does anyone have any other suggestions? I'm just not sure what I should be doing. The monitoring just has not even came up before or after the tune was placed into the truck's ecu. Before this update I was getting to the monitoring screen but had no function at all just like Shaun above.
Return to “Trinity Ford Diesel”
