ABS and Servic Brake System light
Re: ABS and Servic Brake System light
randyc wrote:stock gears, but one size over tires (275). Was going to post my files later today............................should I bother?
sure, lets give it a shot.
randyc
Post by randyc »
hope I did this correct
ECM_12616011_LastTuneWritten.grg
(51.16 KiB) Downloaded 330 times
randyc
Post by randyc »
back up file
ECM_12616011_Backup.grg
(51.34 KiB) Downloaded 265 times
randyc wrote:back up file
load this tune as a custom tune, and choose to reset parameters when it asks
ecm_12616011_abs_fix.grg
(47.44 KiB) Downloaded 245 times
randyc
Post by randyc »
loaded, drove about 1 mile..................lights came back :punisher:
randyc
Post by randyc »
Mike,
Just to make sure I restored the vehicle to stock, then re-loaded the absfix tune, choose reset parameters when asked (only reset axle 3.72 to 3.73 and tire size (went 1/2" lower than friday)................same result, light came back within 2 minutes.
Do you think maybe this fix needs to be "learned"? , in other words might take a few miles to reset completely? I more than likely will be answering that question myself this week because going to leave it as is for now untill y'all come up with something else.(or it "learns" this fix???)
dont change the axle ratio!!!
reload it and reset params.
3.72 is what GM believes is correct, no need to try to tell them how to do it ;)
randyc
Post by randyc »
OK, but I should re-load the correct tire size tho................right?
Let me know and I'll reload tonite
randyc wrote:OK, but I should re-load the correct tire size tho................right?
no, dont make any changes for now, to confirm the tune can go in with no ABS lights.
randyc
Post by randyc »
will do and will post results tomorrow AM
randyc
Post by randyc »
it went farther and I thought today was the day, but at about 15 minutes they came back. I did hook up the GPS and speedo was within 1 mph (or less).......................left everything alone just like you said
Dr.Beardface
Post by Dr.Beardface »
I've noticed with mine that speed is what gets the ABS warning light to come on, not time. Right around 40mph it'll start flashing, but not really ever below that. 2007 Silverado 5.3
randyc
Post by randyc »
Dr Beard, I think you are right........................tho when I was trying to force 3.73 as the correct rear end, it was a time thing and would come on in my neighborhood before 30 mph. Now (back to 3.72 as Mike suggested)it seems to be more of a speed thing as you described. In the morning my 1st 30 minutes are stop and go, then I hit the tollroad and freeways (so it takes around 30 mnutes).............in the evening leaving work, I hop right on the freeway and light comes on with in 5 minutes.
randyc
Post by randyc »
anyone else got a stock truck for them to test?, mine didn't help........................still hoping for fix
cbwallace
Post by cbwallace »
My ABS light has not come on since loading a Lew custom tune! I have driven as couple of thousand miles on the tune and no issue. I hesitate to make any changes as I don't know if this is a fluke or some sort of fix. By the way, very happy with the performance but ay need to increase my tire and fuel budget! :lol:
