No TCM option in tune for me, 2013 Silverado, 6.2l
I've re-flashed it a couple times like suggested below, but the TCM options are still not showing up.
2013 Silverado 1500 6.2l with max towing package. no after market electronics, Nav unit and premium bose system.
- info (2).xml
- (637 Bytes) Downloaded 183 times
- ECM_12649513_Backup.grg
- (62 KiB) Downloaded 203 times
- ECM_12649513_LastTuneWritten.grg
- (61.45 KiB) Downloaded 205 times
Re: No TCM option in tune for me, 2013 Silverado, 6.2l
we'll get it added int he next update
OK, do we have any idea when that might be out>?
ideally early next week.
Rapidly approaching middle of next week, any update on when we might see the update to have this fixed?
Thanks in advance Mike.
any new ETA on this update?
Hey mike, any new eta on this?
Working with Lewis to dial in a tune, and some of my shifting seems a little strange on my WOT runs with out being able to adjust em yet.. getting a little frustrating.
here is the update.
- GM_TUNES-1t01pd.ITF
- (4.82 MiB) Downloaded 248 times
Sweet, thanks I now have the TCM tune as well. will need to play with it a bit, but trying the hard shift tune to start.. =)
Will this update work for me as well? If so, does the auto updater take care of this or do I need to load it manually?
I think it should work for you as well, based on mikes comments, but you would have to drag it in manually, its not being picked up by the updater yet ( i tried the updater first )
I just dropped it on the intune drive after hooking my tool up to my laptop and it installed it.
yes...toyoman wrote:Will this update work for me as well? If so, does the auto updater take care of this or do I need to load it manually?
Well, not surprised but it doesn't work. No TCM. Really discouraged seeing other people get results but none here...
On a side note, these is a bug in this update where if you go into the firmware section, you can't get back out without re-booting.
Toyoman, did you reapply the current tune? it has to be retuned with the current tune with the new file on your intune to show up the new options.
