tune options 06 silverado 2500 hd with the 6.0
westernstar
Post by westernstar »
so i have to diablo pcm tunes and a 87 octane.What are the diablo tunes
Ill_Born_SS
Re: tune options 06 silverado 2500 hd with the 6.0
Post by Ill_Born_SS »
In your case the Diablo tune is for 91 or better octane fuel, if you had a separate 91 tune then the diablo tune would be for 93 octane or better.
" Just Friggin Wicked"
Now with TCM support...
westernstar
it shows this
diadlo tune
87 octane
diablo tune
modify stock
westernstar
also it will allways do an update after it says its updated and can i adjust trq management it only has on and off.what tunes are avail for the 06 silverado 6.0 getting frustrated with this tuner.also there is no gear change setting
what exactly are you frustrated with?
We're here to help, we'll answer any questions you may have.
westernstar
Every time I try to update it wont update to the new update for gm tunes
westernstar wrote:Every time I try to update it wont update to the new update for gm tunes
please post the info.xml file and I'll check out the current versions.
westernstar
K it updated now but now has 2 modify stock tunes 2 diablo tunes and 87 octane tune and stiil no gear change option
the axle ratio param may be missing, if you need it adjusted, please post the tunes from your tunes folder on the intune drive and I'll set it up for you.
westernstar
Sounds good just curious what are the 2 diablo tunes
there shouldn't be 2 diablo tunes...
should be an 87 Octane Tune... and a Diablo Tune (which is for 91+ octane)... and the modify stock tune... that's it...
if you have 2 Diablo Tunes listed, then sounds like a bug/issue... have never seen/heard of that one before....
westernstar
Ya I figured something was wrong 2 diablo 2 modify stock and 87 seemed weird would a for cal fix this and wondering if there is a mileage tune coming out
westernstar
also inable to download dslogredux keeps telling me cant be found??
westernstar
Never mind got it now lol
I would update that intune to see if that double tune issue gets resolved... if it doesn't, then I'd call tech support and see what's up about that before doing anything else..
