06 sierra denali
Re: 06 sierra denali
here you go.
GM_TUNES-1t01pd.ITF
(4.82 MiB) Downloaded 148 times
06denali
Post by 06denali »
I still get the same error message. And just to be sure I download the file and drop it the folder called tunes ?
Othelious
Post by Othelious »
then you have to leave it plugged in for a bit, and you will see the intune evaluate it and install it, it will give you status messages on the screen as it is doing it.
If you unplugged the intune before it updated the file, you may have to delete and recopy it after you plug it back in again.
post a new copy of the info.xml file please.
06denali
Post by 06denali »
Yeah I did that. And it reboot it self.
06denali
Post by 06denali »
<?xml version="1.0"?>
-<tool_info>
<main svn="5947" sw_rev="1r03h" full_version="InTune-1r03h 02/25/2013 05:23:14 PM"/>
<registration status="1" sn="IIREJCC-5"/>
<cal_id PCM="12606807, 12606708, 12591429, 12591469, 12606609, 12591494, 12591530, 12606769"/>
<restore bc="0" vin="2GTEK63N361339925" id="0"/>
<system_db vin="1r01c" dtc="1r01a" info="1r01b"/>
<db pid="1r01a" tune="1r01b" mfr="DCX"/>
<db pid="1r01a" tune="1r01m" mfr="FORD"/>
<db pid="1r01a" tune="1t01pd" mfr="GM"/>
<license tuned="0" avail="1"/>
<updates count="4"/>
<oem tool_oem="DIABLO"/>
</tool_info>
06denali
Post by 06denali »
Its been 11 days. I've never had a problem with the predator tuner. Why am i having problem with the intune??? I'm still waiting...
06denali
Post by 06denali »
Bump ..
06denali
Post by 06denali »
Any luck ?
06denali wrote:Any luck ?
sorry, here you go.
GM_TUNES-1t01pe.ITF
(4.83 MiB) Downloaded 136 times
06denali
Post by 06denali »
Thanks. It's finally working !
sweet, sorry for the delay.
06denali
Post by 06denali »
Okay so the intune works on my truck now. I recently purchased a custom tune from diablewtune. I connected the intune the computer and it pops up Intune and checks for updates. Works fine. Now when I get the custom tune file and drag and drop In the tunes folder. My computer goes to not responding. I wait for a while and it just stays that way. But at the same time I can operate my computer like normal, open another app. Or even search on the web So I unplug it and reconnect it to the computer and intune opens up and then goes to not responding again. What should I do ?
Now it gives me like 30-45 seconds before it freezes. I goto my computer and open the file up and delete the custom tune file. And intune reboots and it work like normal.... I even tried it on another computer and it does The same exact thing. I even connected the intune to my truck and it freezes... I don't know what to do..
so...you load his tune and the intune becomes non responsive?
does the file sit onthe drive, or does it import to the tool?
06denali
Post by 06denali »
When I connect the intune. The intune app opens up and I goto the top left corner and gives me USB or cd rom. I goto USB and I see logs and tunes. I open tunes and I see my back up and last written . I drag the file and drop it in tunes folder. And now I have three files in tunes and that's what it starts the not responding. And intune freezes.
