12 Ram 1500 Crew Cab 5.7 Knock Issue
RogerH
Post by RogerH »
Hey,
First just wanted to say you guys make a great tuner! I just got it two days ago and am LOVING it. BIG DIFFERENCE.
Second:
Seems like I'm having an odd issue when it comes to short term knock..... seems to happen for no apparent reason when viewed with the DS Log Viewer.... I will have a good pull and it wont happen then a little later I will try again and it will knock up to 6--- (5 in the log im attaching).
Im running a modified 91 Perf. Tune:
Modifications to the tune:
Leaned out .5 across the board
MDS OFF
Traction OFF
Speed Gov OFF (190*)
Throttle Boost: 20%
I was figuring it was a lean run issue---however..... I ran a bone stock 91 Perf Tune (no modifications) and it gave me a 4.0 knock randomly. Keep in mind this isnt a constant knock, just seems to happen here and there... I am running 91 Octane fuel (here in Las Vegas I have only been able to find 91 max unless i happen to go to LVMS.....)
Maybe try the 87? ----I have heard here and there that the stock 91 tune may be a little too generous with the spark advance though? Thoughts?
13Mar13.log
(556.32 KiB) Downloaded 111 times
RogerH
Re: 12 Ram 1500 Crew Cab 5.7 Knock Issue
Post by RogerH »
---Im going to go out and run a 87 Tune real quick and see what happens... Ill post the log up to compare and contrast
RogerH
Post by RogerH »
Alrighty---Just went out and ran the 87 Tune..... Just a BIT better----still getting Knock around 3.0........
Again--Running 91 Octane
87 Perf. Tune
MDS Off
Traction Off
Everything else--stock 87 perf. tune.
13Mar13_87Tune.log
(435.72 KiB) Downloaded 112 times
RogerH
Post by RogerH »
So.... A little help would be appreciated.....
Got off of work and decided---Hey... I'll run an 87 tune, retard spark 1* across the range and that should fix it.... Seemed like it did untill I got a random .50 Knock-----and then got a 4.5 knock.... did multiple 0-60s, 60-80mph rolling etc.... problem seems like it comes on at random.........What it the heck? Retarding the spark should have eliminated pretty much all of it. :crashing: :crashing:
add fuel rather than pull timing....
RogerH
Post by RogerH »
added 8% across the board now (richened the mix)---still random 4.5 ST.
Shouldnt pulling timing and increasing fuel reduce knock?
RogerH wrote:added 8% across the board now (richened the mix)---still random 4.5 ST.
could be oil vapors getting in the intake, catch cane may be a good idea.
no amount of fuel or spark adjustment will make it go away if it is oil contamination.
