trinity_dcx_gas-1t09ea
hi guy's,
i just finished to install tune and when i make the change for tire size,
it is write failed to change tire size , but it does change, so my speedo is accurate
Re: trinity_dcx_gas-1t09ea
Same here for my 2011 Jeep Wrangler. 87 oct tune installed and changed TPMS Front/Rear settings but when I set tires to 35" it fails. When I go back in, it shows 35.cawish33 wrote:hi guy's,
2011 Jeep Wrangler Unlimited Rubicon
Same thing with my 11 JK. I am using 1t09f though. Diablo guys might want to check this out.
Any news Diablo? I am now getting a TPMS issue. Set to 26 and getting a warning at 28 lbs.
I did notice that the speedo is showing faster than actual (based upon gps ground speed testing.)
despite saying it failed to change tire size, it actually is, and we are investigating.
hoping to get another wrangler in here as the TPMS stuff worked fine on the truck we had here last....
I updated my T-1000 to 1r09g tonight and retried the TPMS adjustment (aka- Pressure Calibration). I have to save from previous posts, the Tire Size change worked without a hitch this time.
Tried both a Quick adjust and a Modify Tune. Set both the front and rear to 26 #s.
Diablo - FYI - When I adjusted the values and then selected "Yes" on the next screen, it immediately said that it has applied the changes. I thought "Wow" that was fast...but I know it didn't do anything. Tried every way of changing and applying. Same difference.
Would love to get the Low Tire light off my dash. This worked on my Superchips... but of course the Super Chips wouldn't tune!
Please keep trying.
Please keep trying.
Why can a 99$(AEV Procal) turn off the TPMS completely? but the Trinity T-1000 cannot ?
I own both and would be glad to help.
Eat. Sleep. JEEP.
2011 Jeep JKU - D60's
We seem to have figured out how to disable them, an update will be coming, along with a few other cool features for all 05-12 WranglersMatti wrote:Why can a 99$(AEV Procal) turn off the TPMS completely? but the Trinity T-1000 cannot ?
I dont have a specific ETA, but it is coming
Do you know if the fix is in the 10t09g release?
mikel wrote:I dont have a specific ETA, but it is coming
Updates for us Jeep JK guys ???
I need to be able to disable TPMS also some assistance in changing DRL settings and Gear Ratio......
Eat. Sleep. JEEP.
update attached...no need for gear changes on an 11Matti wrote:Updates for us Jeep JK guys ???
- trinity_dcx_gas-1t09hf_update.crom
- (3 MiB) Downloaded 334 times
When I logged into Diablo's site, I found a newer rev - 1t09i. I tried it and got the same result.
Should I try the included hf? I assumed the changes would carry forward.
these changes have not been released, you need this specific update to get them.jdroller wrote:When I logged into Diablo's site, I found a newer rev - 1t09i. I tried it and got the same result.
