no go wot!
herationkane
no go wot!
Post by herationkane »
I have a 2013 gmc 6.6l duramax with the p2040 extreme power puck. with the knob turned to the max I am getting 2-3mpg better, but If I go wot in any gear past 2nd it seems to stall and power is cut. I can let off to 50-60% and it will pull again. I called the tech department today and the guy had no idea what he was doing! I think he was the floor technician! I have the fass 150 on the truck and it still is not running correctly. Please give me some ideas!
Re: no go wot!
did you install the fuel rail shim kit?
herationkane
Re: no go wot!
mikel wrote:did you install the fuel rail shim kit?
No sir, What is this? Where do I get it? What will it do? Thank you.
herationkane
Re: no go wot!
I can't seem to find a shim kit for an lml. can you help please
BigDeez
Re: no go wot!
Post by BigDeez »
Just out of curiosity are you getting any indicator lights? I'm wondering if maybe you are limping it.
Re: no go wot!
its a stack of 3 washers placed behind the pressure relief valve to increase its holding pressure....the instructions are shown inthe manual.
If you didnt get the shims inthe box, please email me your name and address so I can get it out to you.
herationkane
Re: no go wot!
I did not receive the shim kit.
herationkane
Re: no go wot!
BigDeez wrote:Just out of curiosity are you getting any indicator lights? I'm wondering if maybe you are limping it.
It does not have any lights or codes. When I go full throttle it just feels like it is stalling. It actually feels and sounds like its hitting the rev limiter and when I let off some it will start to pull like it should.
herationkane
Re: no go wot!
Tonight I made 2 passes against my buddies Pontiac g8 and from start to close to 1/8 mile it pulled very hard then started acting up. On the second pass same thing then a light came on. It said low fuel pressure and lost com with glo plug module.
herationkane
Re: no go wot!
herationkane wrote:I did not receive the shim kit.
Hello mikel
Re: no go wot!
Sorry, I was out of the office Friday, I got the info over to our guys today.
herationkane
Re: no go wot!
I received the shim kit but on previous models the relief plug is in the end of the rail where the lml just has a sensor that cant be shimmed.
herationkane
Re: no go wot!
mikel, can you please find out how to make this work on an lml?
Re: no go wot!
sounds like the fuel system simply cant keep up, or its dumping fuel pressure which is what the shim kit would have been for....let me investigate.
herationkane
Re: no go wot!
mikel wrote:sounds like the fuel system simply cant keep up, or its dumping fuel pressure which is what the shim kit would have been for....let me investigate.
Did you find a way to make this work for me?
