update
randyc
update
Post by randyc »
any ETA on the update coming to fix the 07 Silverado problem?(abs issue)
Re: update
randyc wrote:any ETA on the update coming to fix the 07 Silverado problem?(abs issue)
restore the stock tune. drag/drop this to the intune drive, let the tool reboot, then load the tunes.
GM_TUNES.ITF
(4.84 MiB) Downloaded 241 times
steelo
Re: update
Post by steelo »
I was able to adjust the tire size, not by how tall the tire is, but by the width, aspect ratio, ad rim size, and have not had the light come back on since. I did not touch the gear size.
Re: update
good to hear :)
steelo
Re: update
Post by steelo »
That could be the solution to any issues people still might be having with the 07. Don't touch the tire size, but do it the way I did.
KBacon
Re: update
Post by KBacon »
I just got my Intune today for my '07 Sierra 5.3...
And after updating today.. I tried setting it to 87 Octane.. Firm shifts.. DoD delete.. tq management -10% 1-2 & 2-3... also set tire size to 275-65-18
and about 2 miles into my test drive I got ABS & BRAKE lights & lots of dinging... came back and cleared codes & went for a test drive again.. and got the same thing at the exact same point in my test drive...
So is the solution to skip the tire size correction???
steelo
Re: update
Post by steelo »
KBacon wrote:I just got my Intune today for my '07 Sierra 5.3...
It worked for me. I have noticed that the ones that can't get rid of that light are adjusting by how tall the tire is. Try it with the other option of Width/Aspect Ratio/Rim Size and see if that helps.
steelo
Re: update
Post by steelo »
Sorry, I misread your post. What I did may or may not work for others. I adjusted the tire and wheel size after I downloaded all of the updates. Maybe try to restore it back to stock, and then retune it. I would not recommend touching the final gear. Even though my truck has a 3:73, the tuner defaults at 3:72. Don't even worry about messing with that, unless you did a gear swap.
KBacon
Re: update
Post by KBacon »
I downloaded this to the intune.. hoping it fixes my issues...
KBacon
Re: update
Post by KBacon »
The above update did fix my issue!!! And the truck is running awesome with the 87 tune
randyc
Re: update
Post by randyc »
I think it worked, will do a long drive today, but when I loaded this weekend and tested had no missues after I installed correctly. (did it wrong the 1st time).
Thanks Mike for not giving up on this...............
Re: update
enjoy :)
randyc
Re: update
Post by randyc »
did a lot of driving yesterday..........................definately fixed!!!!!!!
very pleased......
Re: update
NICE!! woohoo!! :twisted:
