tire size callibration
I still can't change my tire size on my trinity. I've tried by diameter and by metric size numerous times. Is there a fix for this?
Re: tire size callibration
vehicle?
revision?
error?
Help me, help you
revision?
error?
Help me, help you
2012 Dodge Ram
I'll get back to you with the exact error msg
if it says it failed after you set the tire size and cycle the key, it lied
it is working.....
it is working.....
Thanks for the laugh.mikel wrote:if it says it failed after you set the tire size and cycle the key, it lied
it is working.....
i'm running v.1r09f
ok, so it says failed after trying to callibrate like you said.
do i have to reinstall the tune or is it modified on my currently installed tune?
no, the tune is unaffected.
I am serious, when it says it failed, it lied, as long as it had you enter the values and cycle the key.
You can confirm with GPS
ok, thanks for your help.
I bought a 2012 Ram 1500. It had 17in tires, I put on 20's and put the #'s in the Trinity. Now the speedo is 10 kms different then my GPS. How do I get the proper speedo reading?
make some adjustments to the settings until it is correct
Got it figured out, thanks Mikel. Was not hitting the enter button after each entry. Works good if ya do it properly, lol.
