Need help with r30 download
dgparsons2
I installed the r30 download on my predator and it works fine. The problem I am having is that the rkl puff tunes post 28 have an (al) at the end of the tune for the calids. My truck says it has an (AI) calid # so I can not use the custom tunes. Need help as to how I can fix it.
2004.5 Ram 2500 H.O.
4" turbo back exhaust
AFE Intake
Edge Juice w/ attitude
Predator Power puck combo
Transgo shift kit
Modded CP3
Bd auxillary lift pump
AFE Intake
Transgo shift kit
Modded CP3
dgparsons2
RE: Need help with r30 download
Does anybody know?
AFE Intake
Transgo shift kit
Modded CP3
AFE Intake
Transgo shift kit
Modded CP3
i think that i am having the same problem in the topic before!
'03 6-speed, afe stage 2, ats arc flow, 4" str8 threw exhaust,Smarty/Puck, TST PMCR R37, Fass 150, SPS 62/14,60# boost,1600*pyro gauges
dgparsons2
The pre 28 version has the right calid#s but they will not work with the r30 update version.
pre 28 tunes calid #s end with the letters AI just like my truck.
the post 28 tunes calid#s end with the letters al and they dont match my trucks calid #s.
AFE Intake
Transgo shift kit
Modded CP3
AFE Intake
Transgo shift kit
Modded CP3
I'll ask Johan to look into this guys.
Can someone post up the error message you get when trying to load the tunes?
dgparsons2
Blue I got my custom tune to finally download into the truck. The way my truck accepted mine was I installed the regular diablo extreme tune first, then I wrote over that tune with the rkl puff tune no timming added and it accepted it and worked fine. If I tried to install the rkl puff tune on top of the factory settings it keep saying that my calid #s weren't matching up. Try what I did it may work for u to.
AFE Intake
Transgo shift kit
Modded CP3
AFE Intake
Transgo shift kit
Modded CP3
Good catch there....
Re: RE: Need help with r30 download
thank you for the info. just got back inside from programmin' the truck and it worked out PERFECT! thank you for the research labor.dgparsons2 wrote:Blue I got my custom tune to finally download into the truck. The way my truck accepted mine was I installed the regular diablo extreme tune first, then I wrote over that tune with the rkl puff tune no timming added and it accepted it and worked fine. If I tried to install the rkl puff tune on top of the factory settings it keep saying that my calid #s weren't matching up. Try what I did it may work for u to.
I did that as well, it loaded but the truck ran horrible. Idled okay, but when I took off the truck fell on its face and sputtered and acted like it wasn't getting any fuel. I had to just put it back onto Extreme.
Any one have any ideas??
I guess if I ever get time I might try it again, or just go back to the r28 update and then load the RKL. I know that works.
