Concerns !
Personally I would do the Lift Pump and some gauges for starters, are you doing the work yourself? If not you will have to factor in labor.. there's some other guys that may have some more experience then me that could have some better productive suggestions..
03'/305 Dually 4 x 4
Smarty SSR,62/65/13ss, CFM+
I'll do most
I'm hoping to do it all with a friend. He drives a stroker,but he's good at wrenching. I was hoping together we could get it done. If not I guess I'll have to pay.
dgparsons2
RE: What I can afford
Alot of people in the cummins forum say that with a good tq converter and an aftermarket valve body that you can hold up to about 500 to 600 hp if your stock tranny is still in pretty good shape.
2004.5 Ram 2500 H.O.
4" turbo back exhaust
AFE Intake
Edge Juice w/ attitude
Predator Power puck combo
Transgo shift kit
Modded CP3
Bd auxillary lift pump
AFE Intake
Transgo shift kit
Modded CP3
Dodgezilla
Well, your stock turbo and injectors will do for now so I would agree with both of the last posts. First, get some guages, especially a fuel pressure and EGT guage. A trans guage and boost guage are a good idea too. Put the guages on and check your fuel pressure. If it drops to 0 psi on a hard pull then definitely get a better lift pump. Check and see where your EGTS are on a hard pull. If they get too high then you need to start thinking about a better turbo. "Too High" depends on who you talk to. For me, My truck hit 1400 degrees easily stock so I was not concerned at that tempurature too much. I started getting concerned at 1450-1500 degrees which is where I was with my old Quadzilla Race box. My current setup never goes past 1300 degrees but many guys with stock turbos complain of very high temps with their Predators. The cure for that is a bigger turbo. Not too big though.
Next, you will be needing at least a better converter and valve body eventually so it's kind of up in the air on which one you need the most. I'd go for a better valve body so your truck will shift like it is supposed to. Eventually your converter will start to slip but hopefully by then you will have some more $$$ saved up.
Did you say you had $2000 or $10,000???????
04 Ram 2500 RARE Timberline Green 4x4 305/555 CTD/Stock48RE,DS Predator,VA C3.2,HE351 turbo, 2nd gen intake, BHAF,Custom 4" exhaust, More stuff....
On that list you have I would do the TC and valve body. That makes a good difference and probably on milage too.
Reg
RE: Thanks !
I have to say with my current setup "Performance" setting I can easily hit 1600° at WOT. TST 4/3
Dodgezilla
RE: Thanks !
Man! That's hot for an 03!!!
I'd raise your hp setting and lower the tq setting. The tq setting adds duration which is what really gives the high egts. My best numbers running the TST in my 03 were on 7/2......
akdiesel, that sounds good but you should really invest in at least an EGT guage. You'ld hate to put all that $$$ into the truck and then burn holes in your pistons from your temps being too high.....
Re: RE: Thanks !
Once I get over 5 on the TST I have fuel supply issues, so I've been sticking around 4, I'll try setting the torque down, but even without the TST I could hit these temps on Extreme. I have the FASS, just have to do the install. EGT gauge is pre turbo....Dodgezilla wrote:Man! That's hot for an 03!!!I'd raise your hp setting and lower the tq setting. The tq setting adds duration which is what really gives the high egts. My best numbers running the TST in my 03 were on 7/2...........
Thanks for the info !
I guess I'll buy what I can afford for now, and work my way up. I've got a quadzilla commander control monitoring system that I'm going to install, I believe it covers everything egts,boost,trainy,fuel pressure etc.
Dodgezilla
RE: Thanks for the info !
Yup. Good choice AK.
Ropnjessi, come on now! You've had that FASS for quite a while now. It's an easy install on an 03 with the canister mounted LP. Get it done. Remember that too much fuel will drive your temps up in a diesel. Duration gives a lot of extra fuel and so temps will rise. The trick is in getting a good combo of parts that won't raise those temps so high. Every one of these trucks reacts differently so it's hard to say what will work for you for sure.........
Re: RE: Thanks for the info !
I know, I knowDodgezilla wrote:Yup. Good choice AK.
Dodgezilla
RE: Re: RE: Thanks for the info !
Well, it should help but there is no guarantee. As I said, every truck reacts differently to mods so you just keep throwing parts at it until you find the combo that's right.
I believe I have the perfect setup. Great power, great mileage, and low egts. She's not a bad looking truck either. I don't know what more I could ask for.......
