Intune gets stuck on restoring tire size
Andrew.S
Post by Andrew.S »
trying to restore my original tune after the intune failed to write diablo tune
i updated the tuner, but the intune still freezes on restoring tire size on original tune restore
heres all the tunes i have on it
the truck will still start and move just none of my gauges work.
vehicle is a 2005 dodge ram 1500 slt 4.7l
info.xml
(508 Bytes) Downloaded 253 times
TCM_56028953AEA_LastTuneWritten.drg
(115.49 KiB) Downloaded 335 times
TCM_56028953AEA_Backup.drg
(115.49 KiB) Downloaded 233 times
PCM_56028942AF_LastTuneWritten.drg
(57.69 KiB) Downloaded 211 times
PCM_56028942AF_Backup.drg
(57.68 KiB) Downloaded 268 times
Andrew.S
Re: Intune gets stuck on restoring tire size
Post by Andrew.S »
after looking around i see someone else had this happen in the thread "inTune Troubles"
Andrew.S
Post by Andrew.S »
could really use help here thanks
try disconnecting the battery for a minute.
Andrew.S
Post by Andrew.S »
tried still nothing
try restoring QA from the QA menu, then restore the backup.
Andrew.S
Post by Andrew.S »
QA ? I'm not quite sure what that is
quick adjust.
Andrew.S
Post by Andrew.S »
ok well im not finding a QA menu on my intune is there any file that can be downloaded that will fix it from getting "hung" up and restoring tire size right after writing the back up tune
Andrew.S
Post by Andrew.S »
Idk if force original tune would work except it gives me a key code and asks for a password
quick adjust is after tune vehicle/write vehicle.
Andrew.S
Post by Andrew.S »
All I have after that is write vehicle restore vehicle and adjustable parameters. And after going to any of those it just says no ecu found
Andrew.S
Post by Andrew.S »
OK now the truck won't even start
Andrew.S wrote:OK now the truck won't even start
what happened?
please give us a call with the tool powered up in the truck.
Andrew.S
Post by Andrew.S »
im not sure what happened would start yesterday and i havent done anything new but try getting to QA menu
its powered up and calling now
