Geek Failure
Re: Geek Failure
I'm not sure I am following what the issue is?
If the car is tuned, let the tool try to load a tune and it will save the current tune as a backup, and send that to me please.
dbremer
Re: Geek Failure
Post by dbremer »
OK, here it is.
ECM_12650875_BackupDiabloTune.grg
(62.44 KiB) Downloaded 167 times
018 GMC SIERRA DENALI Crew Cab Short Box 4X4, 6.2 Liter,
Re: Geek Failure
drag/drop this file to the intune drive, let the tool import it, then go to truck and select tune vehicle/write vehicle and it will lload the update to set the pcm back to stock.
It may do the same for tcm, if so, post theat file here too.
CTRL_12650875_UPDATE_1GTYKWE29AZ133282.grg
(58.16 KiB) Downloaded 175 times
dbremer
Re: Geek Failure
Post by dbremer »
OK, it did what you said it would. There was nothing new in the tunes directory so that means it didn't do anything with the TCM then, right?
Re: Geek Failure
did it let you reload the tunes?
dbremer
Re: Geek Failure
Post by dbremer »
Yes, and these are the files in the tunes directory after loading the 87 Octane and Firm Shift tunes.
I notice that my custom E85 tune isn't listed in the inTune so I have to import that again, correct?
TCM_24256362_LastTuneWritten.grg
(49.33 KiB) Downloaded 167 times
TCM_24256362_Backup.grg
(49.26 KiB) Downloaded 167 times
ECM_12650875_LastTuneWritten.grg
(62.12 KiB) Downloaded 161 times
ECM_12650875_Backup.grg
(62.33 KiB) Downloaded 176 times
Re: Geek Failure
yup, reload that file, and you are all good :)
dbremer
Re: Geek Failure
Post by dbremer »
Thank you.
dbremer
Re: Geek Failure
Post by dbremer »
Could you check this tune for me? When I load the tune the engine starts, says something about reduced power on the dash display, quits running and won't restart. All the included intune tunes work fine.
dbremer_85grg.grg
E85 Tune
(57.93 KiB) Downloaded 154 times
Re: Geek Failure
where did this file come from?
dbremer
Re: Geek Failure
Post by dbremer »
mikel wrote:where did this file come from?
Andy-Dynotune, then you modded it taking it from the predator to the intune. Sorry for my slow response.
Re: Geek Failure
post a new copy of the backup file from the intune please.
dbremer
Re: Geek Failure
Post by dbremer »
Here it is.
(62.33 KiB) Downloaded 161 times
dbremer
Re: Geek Failure
Post by dbremer »
Did you miss my upload?
Re: Geek Failure
try this file :)
ecm_12650875_dbremmer_e85.grg
(58.13 KiB) Downloaded 156 times
