Owned a I-1000DCX for 2hours & will return it!!!
Wolflead6
Re: Owned a I-1000DCX for 2hours & will return it!!!
Post by Wolflead6 »
mikel wrote:
Wolflead6 wrote:
Mike_Levy wrote:Just keep in mind that if you go with another brand, you're stuck with their canned tunes. No tweaking for your vehicles, no custom tuning, so if you do anything more than an intake and catback exhaust, you're SOL. Besides that, even the tunes that you install on a stock vehicle wouldn't be optimized. Thats why DiabloSport allows the end user to make changes to the tunes, because each individual vehicle is different, and so is each tune.
I don't even know why the other brands continue to make tuners. Next to DiabloSport they look pathetic, like incompetent amateurs.
:punisher: NOT TRUE! My previous Hypertech had similar capabilities as my new I-DCX-1000. Unfortunately, doesn't appear Hypertech has yet broken the encryption on the latest Chrysler products.
I know for sure that they don;t offer custom tuning....:)
True, but other similarities, but then again I still am not able to use my I-1000-DCX for my 2012 JGC 5.7L Hemi because of the ABS light issue. BTW, does the DCX just turn on the ABS light or actually disable the ABS system? Searched Google for the issue and see it goes back to at least 2011 for some folks. Any idea when it will be solved? Can't return it because it is 30 days past return window. Issue didn't pop up until I changed to summer tires and tried to change tire size then WHAM! ABS light issue reared its ugly head. :cry:
