ABS and Servic Brake System light
Re: ABS and Servic Brake System light
yes, its fixed, the updates are posted in this thread :)
outdoorsman
Post by outdoorsman »
Really? Where? All I see is comments about attempts at fixing this issue by changing gear ratios, tire sizes, idle and a custom tune done by someone else - these fixes had different responses showing positive and negative results. The last comment was stating that a fix was coming soon. What was this fix? When I got the unit a month ago I did the update to the intune and the problem still persists. So, perhaps I need you to dumb it down a notch for me :). Where/what is the fix?
outdoorsman wrote:Really? Where? All I see is comments about attempts at fixing this issue by changing gear ratios, tire sizes, idle and a custom tune done by someone else - these fixes had different responses showing positive and negative results. The last comment was stating that a fix was coming soon. What was this fix? When I got the unit a month ago I did the update to the intune and the problem still persists. So, perhaps I need you to dumb it down a notch for me :). Where/what is the fix?
Here you go, drag/drop this to the intune drive and let the tool reboot, then restore the stock tune and reload the new tunes and it will be good to go.
GM_TUNES.ITF
(4.84 MiB) Downloaded 247 times
outdoorsman
Installed the update. Took it for a drive and no more lights!!!
Thanks for the efforts to get this resolved for everyone that has this truck.
good to hear, enjoy.
dreamer
Post by dreamer »
Bumping this thread for the same issue on my '07
I didn't want to start a new one since there are files posted here. I just installed the latest uploaded file from this thread and it still didn't fix my brake/abs lights. They're coming on after a few minutes of driving. (doesn't seems to be speed related at all)
Is there a reason the recently posted file wont work for my 07?
what does your tool show onthe top line of the main menu?
dreamer
Post by dreamer »
mikel wrote:what does your tool show onthe top line of the main menu?
I might not totally understand your question.
I have the Intune plugged into my PC right now and it came up with the 3 options.
Tune Vehicle
Scan Tool
Settings
The top line of this menu is inTune
I don't have access to my truck at the moment. Does it need to be plugged into the vehicle for your question?
sorry, settings/tool info/firmware info, what is the GM tune DB version?
dreamer
Post by dreamer »
mikel wrote:sorry, settings/tool info/firmware info, what is the GM tune DB version?
GM Tune Db: 1t01bb3(*)
load this one:
gm_tunes-1r01q.itf
(4.85 MiB) Downloaded 215 times
dreamer
Post by dreamer »
load this one:
Thanks for the quick help! I will give this a shot and report back.
dreamer
Post by dreamer »
I still need to restore to stock first, and then reload the tune correct?
correct.
dreamer
Post by dreamer »
So, that fix didn't work for me. It took just a few minutes more of driving before they came on, but they did come back.
I have 4 files in the tunes folder. ECM and TCM last tune written, and ECM and TCM backup.
I attached all the files...
TCM_24240463_Backup.grg
(12.55 KiB) Downloaded 170 times
ECM_12614097_Backup.grg
(50.98 KiB) Downloaded 185 times
TCM_24240463_LastTuneWritten.grg
(12.61 KiB) Downloaded 192 times
ECM_12614097_LastTuneWritten.grg
(50.74 KiB) Downloaded 194 times
