Custom Tune
only1d1
Custom Tune
Post by only1d1 »
I need some advice/help with possible paramiters for my 06 Mustang GT. Some of the mods include; Keene Bell Big Bore 2.6l Twin Screw Supercharger, Intercooler, 8 rib pulley system running 10 psi, BBK twin 62mm throttle body, 90mm cold air induction with 93mm MAF, Diablo Sport MAFia, Keene Bell Boost-a-spark and boost-a-pump, 60lb injectors, Moto Blue Coil on Plug w/connector upgrade, Mezzier Electric Water Pump, Canton windage tray, moroso 7qt rear sump pan, JBA cat4ward shortie headers, BMR carbon fiber 1 piece drive shaft, I think that covers it. Anyway, I was running off of the Kenne Bell tune witch was written before any of the other mods were added and the car was "functional". The last items installed were the coil on plugs and the 60lb injectors. I used the 93 octane tune that comes stock on the pred (only factory tunes obtained) and the car isn't feeling to good. :cry: I'll take any help I can get. I am planning a trip to have dyno tuned but would like to be able to drive it to the place. Also anyone running Vista 64 and it works with tuner?
christina
RE: Custom Tune
Post by christina »
With all of that, do NOT run the 93 tune, you can cause major damage running that kind of power on an untuned car.
I will check with the Ford tuner here and see if he has a tune to get you to the dyno facility.
Christy High
lurker.
only1d1
RE: Custom Tune
Post by only1d1 »
Thanks a ton. Yeah I started it and let it run all of about 5 sec and that was enough for me. I will have the car towed if I have to but with the body kit that can pose a problem. Thanks again.
RE: Custom Tune
I dont see hwere you still need anything, based on your other post??
only1d1
RE: Custom Tune
Post by only1d1 »
Christina was going to see if you guys had a tune I could use to get to Amazon Racing. I have know contacted Phil J and he turned in the info to your Ford eng to take a look at. Just waiting on status now?
Return to “Predator Ford Gas”
