I'm starting to feel the same way it has been 3 days that they said it would be "today" starting to sound like the boy who cried wolfOconer wrote:i really doubt this tune will be up today lol this is a dam joke...
2012 Dodge Challenger 3.6 Intune Problem?
Re: 2012 Dodge Challenger 3.6 Intune Problem?
Soooooo is they any update on whats going on yet?..... or will it will be up this afternoon be the same answer again for what the 4th day in a row now??
A stupid question for Mike L, what would happen if u are using the 93 oct + CAI tune and you are using 94 oct gas? (Negative effects?)
And what would happen if u use a similar tune and you throw in an octane booster in your tank, like a +6 point octane boost??[/quote]
Octane is a measure of knock resistance, the higher the octane the more resistance to knock. You can run any octane above the octane rating of the tune, say the 87 octane tune with 93 octane fuel, no problem, but don't run fuel with a lower octane rating than the tune being used because the lower octane fuel can't resist the knock that will be present with the advanced timing of the higher octane rated tune.
Don't worry it will be out "Today" a.k.a next monthGriffin26 wrote:Soooooo is they any update on whats going on yet?..... or will it will be up this afternoon be the same answer again for what the 4th day in a row now??
inTune was released at 1:00 PM.....
Still not working whats going on heremikel wrote:inTune was released at 1:00 PM.....
if it was released where is update for mac users?
you need both files.Oconer wrote:if it was released where is update for mac users?
will test out as soon as its all done downloading. will post back results in a minute
it is saying PCM calibration for 23CDYAG7CH206593 might need an update. check for a calibration update? and i click the green check and does absolutely nothing
They still working on it, hopefully one more hour!!
- Ill_Born_SS
It wants you to unhook from the car and reconnect to your computer for a calibration update... then return to the vehicle and load the new calibration. Then you can proceed to install a tune.Oconer wrote:it is saying PCM calibration for 23CDYAG7CH206593 might need an update. check for a calibration update? and i click the green check and does absolutely nothing
" Just Friggin Wicked"
Now with TCM support...
Did that and got this after connecting it to the computer, "An error occurred. Info: Please contact [email protected] using Calibration ID 68089520AH."Ill_Born_SS wrote:It wants you to unhook from the car and reconnect to your computer for a calibration update... then return to the vehicle and load the new calibration. Then you can proceed to install a tune.Oconer wrote:it is saying PCM calibration for 23CDYAG7CH206593 might need an update. check for a calibration update? and i click the green check and does absolutely nothing
HVACref mech Mitch
ditto, same happened to me as zeropilot. hmmmmm any ideas anyone? (pc user)
mikel wrote:you need both files.Oconer wrote:if it was released where is update for mac users?
Yo, Mikel where does those files go??? it says An error occured. Info: Please contact [email protected] using Calibration ID: 68078638AF Status: Error Please contact tech support for help.
BTW, im helping him out. here is a screen shot of what it shows on PC.
