Car Won't Start After PCM Reflash
Re: Car Won't Start After PCM Reflash
you need to download dsdownloader from the U7146 downloads page and use it to export a copy of the stock tune from the tool.
- U7146_U7142_U7153_custom_tune_instructions_NEW.doc
- (30 KiB) Downloaded 366 times
that downloader does not exist. I click on the link and it says your site does not have it anymore.... it says ...... "the internet site reports that the item you requested could not be found"
I got it. Here is my tune, thank you.
- CVAF1CX tune.frg
- (224.25 KiB) Downloaded 256 times
here you go, load this, and it should fire up.matt00gt wrote:I got it. Here is my tune, thank you.
- cvaf1cx tune_PATS_disable.frg
- (224.13 KiB) Downloaded 254 times
I don't know how much to thank you, my car drives better than ever. Thanks man!
thats just a stock tune
once you get the keys reprogrammed, you can switch to the perf tunes
I'm running nitrous anyways for the time being so the stock tune is perfect.
How would I go about reprogramming the keys?
a ford dealer or someone with IDS can reprogram the VATS so the car will start without that tune
I hope they pay you really well because you guys keep customers for life with this kind of customer service
Thanks again for everything. And I'm guessing you mean PATS when you wrote VATS"?
oops, yup, VATS is a GM thing
