updating i-1000
updating i-1000
My truck is set on 87 tune right now. going to be plugging it into comp for the first time to check for updates (place I bought it from updated and set on 87 tune for me when I got it). do I need to return to stock tune before doing so? or just reload 87 tune after updates if there are any? (I,m guessing they did registration also ).
Re: updating i-1000
how long have you had it?
Re: updating i-1000
about 2 hours
Re: updating i-1000
also i just pluged into comp went through registration didnt get email to finish... retry and it says its done already .....confuzzed?
Re: updating i-1000
you're good to update without restoring
Re: updating i-1000
comp is saying cant find drivers for it . the reason I asked first question is he seemed leary on update while at shop. but it says is up to date on my comp. sat in seat as he loaded 87 into my truck , drove home about 9 miles and not being able to tell a difference . wonder if its working correctly or not.
Re: updating i-1000
should I give update a try? maybe it needs to be driven longer to learn new setting ???
Re: updating i-1000
upon 2nd try drivers were not loaded but still says already registered and I never got email to finish ... maybe he done that at shop? o well guess i,ll keep assing around with it
Re: updating i-1000
<?xml version="1.0"?>
-<tool_info> <main svn="6254" sw_rev="1r03j" full_version="InTune-1r03j 05/29/2013 01:30:58 PM"/> <registration status="0" sn="IGU3KA1-2"/> <cal_id CM2="20964291, 20964272, 20964263" CM1="24255281, 24255562, 24255559, 24255563" PCM="12653674, 12649538, 12649507, 12625892, 12620690, 12640912, 12649842, 12649812"/> <restore bc="1" vin="1GCNKPEA7DZ328608" id="0"/> <system_db vin="1r01c" dtc="1r01a" info="1r01b"/> <db pid="1r01a" tune="1r01b" mfr="DCX"/> <db pid="1r01b" tune="1r01n" mfr="FORD"/> <db pid="1r01a" tune="1r01q" mfr="GM"/> <license tuned="1" avail="1"/> <updates count="1"/> <oem tool_oem="DIABLO"/> </tool_info> (got this to come up if that helps)
Re: updating i-1000
were do i find serial no for unit ? giving regestration another go .. noticed year and such was correct but not motor size?
Re: updating i-1000
IGU3KA1-2
Re: updating i-1000
ok redid with corrections but no email sent to me to finish??? maybe ill try later if I get email. bye the way thanks for try to help me here. out of time for now i'll try later
Re: updating i-1000
I asked our IT guy to look into this for you.
Re: updating i-1000
thanks ill be waiting on reply
Re: updating i-1000
I would like to possibly start from scratch here if I need to, having many lock up problems trying to change to diablo setting, unplug and tryed again with success now i've got the little 4.8 litre woke up .still need to get registration figured out ....
-<tool_info> <main svn="6254" sw_rev="1r03j" full_version="InTune-1r03j 05/29/2013 01:30:58 PM"/> <registration status="0" sn="IGU3KA1-2"/> <cal_id CM2="20964291, 20964272, 20964263" CM1="24255281, 24255562, 24255559, 24255563" PCM="12653674, 12649538, 12649507, 12625892, 12620690, 12640912, 12649842, 12649812"/> <restore bc="6" vin="1GCNKPEA7DZ328608" id="0"/> <system_db vin="1r01c" dtc="1r01a" info="1r01b"/> <db pid="1r01a" tune="1r01b" mfr="DCX"/> <db pid="1r01b" tune="1r01n" mfr="FORD"/> <db pid="1r01a" tune="1r01q" mfr="GM"/> <license tuned="1" avail="1"/> <updates count="1"/> <oem tool_oem="DIABLO"/> </tool_info>
