P0133 code
- Ill_Born_SS
Re: P0133 code
Simply swap the front O2 sensors from side to side and see if it changes sides. Also if there is a leak at the throttle body then you have an inaccurate tune to start with. (lean which would be a slow response)
" Just Friggin Wicked"
Now with TCM support...
Re: P0133 code
^ Thanks I cant believe I didn't think of that. I will give that a shot and see what happens. If it turns out to be just the o2 sensor, which is only 3 months old, is there a better brand that I can use. Ive heard of people using Corvette o2s for whatever reason.
2007 Dodge Ram 5.7 Hemi, Trinity CMR tune, K&N FIPK, 87mm ported TB, Dynatech Supermaxx LT headers, Magnaflow cats & ypipe, Magnaflow muffler, Jetstream Scoop, DIY Ram Air, 2" level kit, blacked out brake lights, all chrome blacked out
Re: P0133 code
What brand are you using? Bosch or NGK are the best out there. I believe NGK is who makes the stock Mopar ones.
Re: P0133 code
honestly im not sure. my dealership replaced them all when they could not figure out why the light kept coming back on. even after replacing them all. it wasn't until I got my CMR tune that the light stayed off for about 2 and a half months. but now it keeps coming back once or twice a week.
Re: P0133 code
I installed BBK shorty headers myself (which I shouldn't of done cause i'm an idiot and I have only jack stands), anyways I had to get what I did fixed (used the bbk gaskets instead of new stock ones) so i saved myself no money.Ill_Born_SS wrote:Simply swap the front O2 sensors from side to side and see if it changes sides. Also if there is a leak at the throttle body then you have an inaccurate tune to start with. (lean which would be a slow response)
now, I run 94 octane gas, i got that same code. 02 sensor bank 1 slow. had the 93 tune with 5% fuel across the board, So I "downgraded" to the 91 tune (added 1% fuel across all) got the code, went to the dealer and got the 02 sensor replaced (under warranty thanks to my buddy working there
I got to reading that headers will lean out your a/f by 5-10%, and that these tunes are on the safe side of lean to begin with, could that just be my issue?
I do have an a/f gauge that I have sitting in a box waiting for me to get the balls to install also a cervini ram air kit (even more lean than my current CAI).
What's a safe fuel add? Too much fuel will foul your plugs or burn your cats out no?
Re: P0133 code
O2 harness resting on the headers?
Re: P0133 code
i have no way of seeing. i'll have to find out I guess once i can get time and put her in the air.mikel wrote:O2 harness resting on the headers?
Re: P0133 code
my p0133 turned out to be a leak in the headers where they run parallel. Got it fixed and for the first time I threw a p0153. Also ever since I got my CMR tune when I come to a stop my rpms start to drop like normal but fall just below 500 and jump back up quickly. This is pretty annoying especially if I am resting light on the brake and can actually feel it jump forward a little. I was thinking of switching it back to the factory tune to see if it still does it.
Re: P0133 code
Id suggest letting your tuner know about thatRamMan86 wrote:my p0133 turned out to be a leak in the headers where they run parallel. Got it fixed and for the first time I threw a p0153. Also ever since I got my CMR tune when I come to a stop my rpms start to drop like normal but fall just below 500 and jump back up quickly. This is pretty annoying especially if I am resting light on the brake and can actually feel it jump forward a little. I was thinking of switching it back to the factory tune to see if it still does it.
