pressure ratio scaling
rmcr
Post by rmcr »
2009 dodge challenger tune from diablo i am using is: 68004308ag
the pressure ratio only goes to 1.0 in this tune.
what all would be necessary is raising it to 1.5? as I have seen in a dodge 300 tune that is: 04896600al
is it just a matter of re scaling all the axis that are related to PR? is there a way to go about with without having to retune the entire maps?
car is supercharged with vortech 9 lbs. and a little more resolution would be desireable since it gets to 1.0 PR pretty easily
thanks
Re: pressure ratio scaling
yes, you can right click in the x/y axis and select show normalizers to edit them. You'll need to remap the tables once you do so.
msmechanical
Post by msmechanical »
Mikel what are the rules for altering these axis?
i only ask because i have had idling issues once i changed them ,,
but now i only alter the top half of the pratio axis, and never any lower than say .7,, have had better luck this way , i never touch the rpm scales.
are there rules if you change one normalizer in say WOT spark , do you have go through and ensure ALL spark tables are the same axis values?
i ask this question because again , i have had issues where part throttle spark and min spark were different and massive idle hunting was evident,
cheers
manny :)
thats a better question for Johan or Brian, id post it in the CMR dodge tuning section...
