Trying Predator U7135 again after 2 years
BamaBoi
Post by BamaBoi »
2006 - 300C - 5.7L
u7135 9r12
K&N Typhoon Filter
Borla Catback
Problems:
My MDS again is kicking very stiff on the interstate when on cruise control. While in the stock tune I can hear the MDS drone but I never feel the system engage.
Down shifting from 2nd to 1st gear under normal driving (Not using the auto-stick) while stopping seems to "drone" or "hesitate" slightly longer than it seems it should. The car is not stalling and there are no codes associated.
- I saw a post about a "MDS Smooth" adjustment Mike made for a client. Is there something I can do to make that kind of change and what exactly is the cause?
I drive conservative when kids are in the car and spirited when they are not. Functionality of the vehicle is excellent. I have exceeded services and recommendations for the vehicle maintenance. Recently flushed/replaced the tranny fluid and filter, inspected suspension components, replaced sway bar end links and bushings, put on a new belt tensioner and gatorback belt, new plugs (OEM), new brake pads, turned rotors, new tires, etc...
I did reset the TCM Module and lowered the Fan Speeds by 5 on all points for fun. No other changes to the 91 Oct CAI tune was made.
:arrow: The last time I used the tuner I remember reading in a manual or online a statement like "89 Octane could be used on the 91 Oct Tune". I now see in every discussion I could find that this is not recommended?
Thank you.
2006 Chrysler Heritage 300C - K&N CAI, Borla Exhaust w/ 5' Tips, Diablo Sport 91 OCT Tune, Jet Powertech Thermostat, LED Upgrade, Lots of sound.
Re: Trying Predator U7135 again after 2 years
post the LTW...
no, using 89 with the 91 tune is a terrible idea.
BamaBoi
Post by BamaBoi »
So after another drive today it still seems to stay in 2nd a little longer than necessary and the MDS disengagement back to 8 cylinders at highway speeds is very noticeable.
Any help you can give is very appreciated.
Why is it noted as custom? I didn't change anything... MDS-On, ESP- ON, No thermostat upgrade and I reset the TCM last time and unplugged the battery last night as I was doing some unrelated work on the vehicle?
Should I reinstall factory tune, load the updated file into the tool and then re-install "Custom Tune"?
05094779AL_custom.drg
(4.25 KiB) Downloaded 233 times
BamaBoi
Post by BamaBoi »
[quote="mikel"]post the LTW...
no, using 89 with the 91 tune is a terrible idea.[/quote]
I removed the tune again because of the listed issues. What is the turn around for a modified tune?
here you go.
05094779al_smooth.drg
(47.25 KiB) Downloaded 276 times
BamaBoi
Post by BamaBoi »
[quote="mikel"]here you go.[/quote]
Thanks mike. I'll let you guys know how it turns out.
BamaBoi
Post by BamaBoi »
The shift points are smoother under deceleration but that wonderful MDS drone is still very pronounced...
Mike, Can I just turn off the MDS with this tune or should I go back to a CAI 91 Oct canned version with MDS disabled?
Again, The shift points are enjoyable but the cylinder shutoff moments (both sound and 1 second hesitations to kick throttle back in) spoil the fun.
you can turn it off with either tune...
