2011 Ram 5.7/400 stroker
Javier_Wilde
My concern is my tranny holding up the torque(545rfe). Can you make the tranny stronger with a tune?.
Re: 2011 Ram 5.7/400 stroker
Maybe adjust the shift pressure with the tuner but idk if you can do it on the new trucks.
How can you make a mechanical part stronger with a computer? You can't. You need to get a SharaDon transmission. Getting a built tranny is the only way to make it stronger.
Javier_Wilde
So is the 545rfe stronge enough to hold up with 400 cu?. Im not talking about hard launching. This is me with stock 5.7... http://www.youtube.com/watch?v=-Z1OgxLrS9g
It probably could, but a Stage 2 or Stage 3 would be far preferable and much safer. http://www.sharadon.com/sdtestparts.htm
