MODIFIED PARAMETERS
T91WHEELER
MODIFIED PARAMETERS
Post by T91WHEELER »
If I have a 91 CAI tune in with some modified parameters...for example +10% fuel from 1,000-3,8000, how do I verify this? If I go to modify parameters will it show where the parameters currently are set? It seemed in the past, that when I went to modify parameters such as fan "on" temps the tool didn't show where they were currently set but went back to the standard settings for that particular tune(?). On the other hand maybe I still had the default tune in and didn't realize it...
I recently took car in for some dyno pulls and had some parameters tweaked. I want to be sure I know the settings in case car gets flashed back to stock at the dealer for example.
I want to know the answer before I go in experimenting and accidentally screw something up and/or loose my current tune.
Thanks for your help.
RE: MODIFIED PARAMETERS
You can either look at the parameters to see where they are set, or, better yet, extract a copy of the last tune written from the Predator, and save it to your PC. Then you can load it as a custom tune at any time, and not have to make any changes...
Mike
