2011 Dodge ram shifting issues...when's the fix coming?
white_lightning
Re: 2011 Dodge ram shifting issues...when's the fix coming?
Post by white_lightning »
2012 Ram cal #'s that I have tuned that have this issue:
68064937AF
68064931AF
68064938AF
68064939AF
68064929AD
68064926AF
68064920AD
68064933AD
68064921AF
68064919AD
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
2011Longhorn
Post by 2011Longhorn »
calid 68059108AH
PCM_68059108AH_Perf_93oct_modified.drg
(4.25 KiB) Downloaded 279 times
johan
Post by johan »
Please try this, i think i found the issue here.
I just edited this post, screw up on that first file, did not realize it was from an older version, i have updated the file here so please discard the 001 file
pcm_68059108ah_perf_93oct_modified_002.drg
(84.08 KiB) Downloaded 279 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
sarah_ima64
Post by sarah_ima64 »
calid
68067141AH
i want shift 1 - 6000
2 - 5950
PCM_68067141AH_Perf_91oct_modified.drg
(3.25 KiB) Downloaded 207 times
2005 RAM 1500 Daytona : Diablosport Trinity, CAI Airaid, Headers JBA, Catback Borla.
2009 RAM 1500 SLT 4x4 : Diablosport Trinity, CAI Airaid, headers JBA, Catback Flowmaster.
2011 RAM 1500 Laramie 4x4 : Diablosport Trinity, CAI Airaid, Catback Magnaflow.
johan
Post by johan »
what rpm do you want the shift points at?
Diablosport INC
d o d g e
Post by d o d g e »
what was the problem with the shift points? you forgot the tune you wrote for me dave.
11 Ram,93oct LT Hdr,2kP-T 6Kwot,N.Villarreal.drg
(84 KiB) Downloaded 271 times
2011 sport cc: vararam, 87mm tb moes per., bt catch can, 180t-stat, arh longtubes, magna flow catback 5" tips, 2800 edge, 4.10's lsd, two custome tuned pcm/tcms
d o d g e wrote:what was the problem with the shift points? you forgot the tune you wrote for me dave.
you wanted 6000 rpm shifts?
d o d g e
Post by d o d g e »
yes i did... 6 k shifts thank you! :D
johan
Post by johan »
here we go
11 ram%2c93oct lt hdr%2c2kp-t 6kwot%2cn.villarreal_001.drg
(84 KiB) Downloaded 309 times
Diablosport INC
sarah_ima64
johan wrote:what rpm do you want the shift points at?
6000RPM
d o d g e
Post by d o d g e »
johan wrote:here we go
Johan can you actuall change this to 6200 rpm shift please! Thank you in advance. :D
white_lightning
Nick, I would advise against 6200rpm WOT shifts. if they are actually going to start happening as commanded, you will spin up to 6300- 6350 while WOT shift is completing. bit high for a stock Gen IV Hemi, IMO.
emailed you a tune refinement.
My Ride:
marku
Post by marku »
Any updates Dodge? How did it shift?
2011 Ram RT. vararam intake, ARH 1 7/8, Corsa exhaust, Diablo Catch Can, Arrington 85mm TB, V6 fan install, Edge 3400 convterter. Trinity CMR by Duster360 & Whitelighting.
d o d g e
Post by d o d g e »
marku wrote:Any updates Dodge? How did it shift?
Haven't tested it out yet I will do that this morning and let you here shortly :D
marku
Post by marku »
Log it too and let it shift 2-3 cause that's where mine bounced off the limiter
