new laptop config
new laptop config
The application failed to start because its side by side configuration is incorrect. Please see the application event log or use command-line sxstrace.exe tool for more detail. loade cmr 5.0 and this message comes up when trying to start program same message for data viewer
thanks
thanks
Re: new laptop config
No luck have tried to load this and the one on cmr downloads it will not load. http://download.microsoft.com/download/ ... st_x86.EXE Also will need FTDDll for chip burner
Tom
Tom
it wont load??
what happens when you try to install it?
Sorry install it. Past 2 times gets thru security scan then accept agreement then shows installing then stalls then shows another error message same as post you sent me to.
Microsoft.VC80.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.6195" could not be found. Please use sxstrace.exe for detailed diagnosis.
O K save file then installed and all is well in my world for the next 5 minutes. Just need link for ftd chip burn
Sorry for any trouble always love setting up a new computer.
what is the exact name of the .dll file it is asking for?
actually, what OS is on this new PC?
OS is 7 win 8 ready file is FTD2XX.dll I have seen this before and tou emailed file but that was about 3 4 yrs ago.
win 7 64 or 32 bit?
64 bit will not work with the burner.
if its 32, put this file here:
C:\ChipMaster Revolution\Revolution Applications\Burner
- FTD2XX.dll
- (172 KiB) Downloaded 546 times
Next 1 MSVCR71.dll is missing Thanks
Im not sure how thats related to the burner, as it goes here:japzap33 wrote:Next 1 MSVCR71.dll is missing Thanks
C:\ChipMaster Revolution\Revolution Applications\DAT
But give it a shot.
- msvcr71.dll
- (340 KiB) Downloaded 561 times
