P061B error
Virge
P061B error
Post by Virge »
Hi, i have this tune, but the wrench light come on with this error p061B and P2106. What is the problem?
My car is a Ford Mustang V6 4000 cc, 2005, with bbk cai, bbk throttle body 70 mm, shorty headers.
91R-R2.frg
(960.13 KiB) Downloaded 272 times
sohfast94
Re: P061B error
Post by sohfast94 »
Could you please post your original backup?
Insert Clever comment here...
Virge
Re: P061B error
Post by Virge »
Ok, this is my original backup!
Why do I have the P061B error? I have noticed that if the tune is lean, it doesen't appear, but when they correct the tune adding more fuel, the P061B comes on...
FBBS2B2.frg
(960.25 KiB) Downloaded 292 times
sohfast94
Re: P061B error
Post by sohfast94 »
also what revision is on your predator? top right when it's powered up.
Virge
Re: P061B error
Post by Virge »
U7140, revision 9r09
Virge
Re: P061B error
Post by Virge »
Othe original backup is the same before and after updating the predator?
I have an original backup saved on my pc. I have updated the predator but I never replaced the original backup saved on my pc. When I did a custom tune I sent the original backup saved with old revision of predator. Is this the problem about my error?
Virge
Re: P061B error
Post by Virge »
I go to ford, and i update my pcm, but i have the same problem. I turn on the car, the rpm go to 2000, put the automatic transmission in D, and wrench light come on with p061B and P2106...
i attach the my new original backup, and my custom tune. can you check this?
91S-R7.1.frg
(960.18 KiB) Downloaded 272 times
FBBT057.frg
(960.25 KiB) Downloaded 294 times
sohfast94
Re: P061B error
Post by sohfast94 »
Give that a try.
fbbt057_R2.frg
(960.14 KiB) Downloaded 293 times
Virge
Re: P061B error
Post by Virge »
I try your tune, if i go slow the car doesen't have any problem,but when I press hard the gas pedal the P061B and P2106 come on...
on the attachment you can find the last tune written (your tune). What is the problem?
FBBT057_custom.frg
(6.25 KiB) Downloaded 287 times
sohfast94
Re: P061B error
Post by sohfast94 »
Must be something with the torque monitor. Or you truly have something wrong with the TB. Load this.
fbbt057_r3.frg
(960.14 KiB) Downloaded 265 times
Virge
Re: P061B error
Post by Virge »
I try it seems work!! i drive for some miles and i don't have any errors!
what can you do??
sohfast94
Re: P061B error
Post by sohfast94 »
What can I do about what? I don't understand.
Return to “Predator Ford Gas”
