2011 Dodge ram shifting issues...when's the fix coming?
Tyler11Express
Re: 2011 Dodge ram shifting issues...when's the fix coming?
Finally got a chance to try out the 6200 shifts today. 1-2 works flawlessly, shifts nice and firm. There's still a problem with 2-3, it shifts at 5800. Tried it with autostick and the dame thing happened. Hopefully you guys can get this fixed too. It'd be perfect to be able to cross the 1/8 in 2nd.
post a copy of the last tune written please.Tyler11Express wrote:Finally got a chance to try out the 6200 shifts today. 1-2 works flawlessly, shifts nice and firm. There's still a problem with 2-3, it shifts at 5800. Tried it with autostick and the dame thing happened. Hopefully you guys can get this fixed too. It'd be perfect to be able to cross the 1/8 in 2nd.
Tyler11Express
I'm running the 6200 WOT tune you posted on the last page. I tried reflashing it today and still 5800 2-3 shift with it set at 6200.mikel wrote:post a copy of the last tune written please.Tyler11Express wrote:Finally got a chance to try out the 6200 shifts today. 1-2 works flawlessly, shifts nice and firm. There's still a problem with 2-3, it shifts at 5800. Tried it with autostick and the dame thing happened. Hopefully you guys can get this fixed too. It'd be perfect to be able to cross the 1/8 in 2nd.
It's going to take some minor adjustments Tyler. The tune I got from Johan and Dave are shifting over 6100rpm 2-3.
2011 Ram RT. vararam intake, ARH 1 7/8, Corsa exhaust, Diablo Catch Can, Arrington 85mm TB, V6 fan install, Edge 3400 convterter. Trinity CMR by Duster360 & Whitelighting.
post the last tune written from the tool please.Tyler11Express wrote:I'm running the 6200 WOT tune you posted on the last page. I tried reflashing it today and still 5800 2-3 shift with it set at 6200.mikel wrote:post a copy of the last tune written please.Tyler11Express wrote:Finally got a chance to try out the 6200 shifts today. 1-2 works flawlessly, shifts nice and firm. There's still a problem with 2-3, it shifts at 5800. Tried it with autostick and the dame thing happened. Hopefully you guys can get this fixed too. It'd be perfect to be able to cross the 1/8 in 2nd.
Tyler11Express
Tyler11Express
Ok.
- PCM_68057118AH_whitelightning_6200wot.drg_modified.drg
- (5.25 KiB) Downloaded 274 times
Try this one and make sure to reset your parameters when loading this one in.
- pcm_68057118ah_whitelightning_6200wot_001.drg
- (83.93 KiB) Downloaded 312 times
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Tyler11Express
Awesome thanks for the quick reply Johan.
Tyler11Express
OK just got back from doing a couple test runs with the latest revision and it's still doing the same thing in Drive, 6200 1-2 and then 5800 2-3. It'll hold 2nd all the way to 6200 though if I manually shift it to "3rd"(2nd Prime), but I really want to keep it out of 2nd Prime!
If resetting the parameters do change anything do a battery reset for about 60'sec.Tyler11Express wrote:OK just got back from doing a couple test runs with the latest revision and it's still doing the same thing in Drive, 6200 1-2 and then 5800 2-3. It'll hold 2nd all the way to 6200 though if I manually shift it to "3rd"(2nd Prime), but I really want to keep it out of 2nd Prime!
2011 sport cc: vararam, 87mm tb moes per., bt catch can, 180t-stat, arh longtubes, magna flow catback 5" tips, 2800 edge, 4.10's lsd, two custome tuned pcm/tcms
Don't*d o d g e wrote:If resetting the parameters do change anything do a battery reset for about 60'sec.Tyler11Express wrote:OK just got back from doing a couple test runs with the latest revision and it's still doing the same thing in Drive, 6200 1-2 and then 5800 2-3. It'll hold 2nd all the way to 6200 though if I manually shift it to "3rd"(2nd Prime), but I really want to keep it out of 2nd Prime!
post the ltw please.
Tyler11Express
I loaded the stock tune and drove it home about 25 miles. I disconnected the battery for a couple minutes then reloaded the latest tune and still the same thing, in drive it'll shift at 1-2 at6200 or so and then 2-3 at 5800 or so. Marku is not having this problem.
Like I said if I manually shift it, it'll hold 2nd to 6200 then I press the up shift on the column to "3"(2nd prime) and again it'll hold till 6200 then I press the up shift to "4"(really 3rd gear). I don't want to go into "3"(2nd prime) at all costs, I want it to shift to 3rd gear on it's own.
Here's the latest tune written,
- (83.93 KiB) Downloaded 261 times
buellrider
How do I get the new shift rpm for a 2012??
